Pinging sound
Old Mar 18, 2010 | 07:30 PM
jgreg65's Avatar
jgreg65
Default Pinging sound
Hey Guys,
I have recently been getting sound from the cylinders like only when you really hammer on it like a low octane pining sound. I will next time make sure I use HIGH test which I'm pretty sure I did but I'll check twice. What do you guys think?
Old Mar 18, 2010 | 07:39 PM
Buzzsaw's Avatar
Buzzsaw
Bad / Cheap Gas, Timing is off? do you have a Tuner on the bike...I would get it from 3500-4500 at WOT when it was really hot...Tuner tweaked the timing in the PCIII and it went away...
Many things can cause it and most guys who can give a better answer than my guess will need to know the build, and the Tuner on the bike to give some advise.
Old Mar 18, 2010 | 07:41 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
sometimes its poor fuel (winter blend)but 07 and up are tuned very lean from the factory a tuning aid (wich is best is for another thread) took care of the issue for,if it gets worse in the summer heat with good fuel a tune is in your future.
Old Mar 18, 2010 | 07:55 PM
Petesnot's Avatar
Petesnot
If you're lucky, its just one tank of bad gas. However, with all the methane now in gas pinging is common. If you get a fuel management system, be sure to get one that adjusts timing - not just fuel. You might be able to retard the timing to eliminate it. Short term - a bottle of octane booster will work. Follow directions on the bottle.
Old Mar 18, 2010 | 10:57 PM
Trek's Avatar
Trek
Good suggestions already given. I believe it is fuel detonating too early in the stroke. Per my mechanic and my experience that can be caused by poor fuel, timing a bit off, not enough fuel in the map.
Good luck!
Old Mar 19, 2010 | 12:04 AM
user 8373900's Avatar
user 8373900
ethanol...
Old Mar 19, 2010 | 04:36 AM
jgreg65's Avatar
jgreg65
Ok sounds good guys I'm going to try some octane boost to start out with. And hopefully thats all it is. I really wanted to wait at least a season to do anything to the motor.
Old Mar 20, 2010 | 04:25 PM
Beemervet's Avatar
Beemervet
Pinging is not just an irritating sound. It is the sound of your engine destroying itself. Do whatever you must do to stop it ASAP.
Old Mar 24, 2010 | 11:34 PM
XsjadoNightster's Avatar
XsjadoNightster
Nice!
rotherdrummer
Jun 23, 2014 09:20 AM
gseely
Jul 12, 2010 07:38 PM
kk6pg
Apr 30, 2008 01:17 PM
mgmmgm
Apr 17, 2008 04:49 PM
akenaten
Aug 17, 2007 03:22 PM
