My friend hsa an 04 ultra and thought he was taking out the tranny drain plug and mistakenly unscrewed a small alan head screw on the bottom of the engine case on the right side of the case. about a half cup of what looked like engine oil drained out. What the heck was that ??
Thanks
the one you labeled "primary, 1 of 2. so when you drain the primary with the drain plug on the primary case you do not nee to touch the other one. what is it there for?
thanks
Thanks
I believe that was where they plum in the engine temp gauge.
It's the drain plug for the crankcase. You pull it to check for sumping. 1/2 cup oil is good. The one to use for your oil temp gauge is the one marked "crank" in soos's picture.
Thanks
did you ever find out
Watt those bolts where. I did the same thing but I cant unscrew mine Im thinking its for the oil son that sits there in the bottom of the crank case. Maybe you could drain it out that way
