Sweet smell?
Old Mar 21, 2010 | 08:57 AM
'05Train's Avatar
'05Train
Default Sweet smell?
I've got a weird issue.
For a while now, but worse over the last week or so, I've had a smell coming from the bike, that is more pronounced when slowing down, but is pretty much always there. It's not leaking anything, and I've washed it to make sure that nothing was sitting and cooking on the engine.
The bike's a 2010 FLHTK with 3300 miles, Amsoil in all 3 holes (ATF, 75-90, and 10W-40). The weather's warmed up quite a bit over the last week or so. Bars were replaced last weekend, so the clutch cable was done then too. Front fork oil was swapped to Amsoil 5wt. Stock exhaust came off Friday and a Fatcat went on.
The bike runs fine, shifts fine, and stops fine. There's a fair amount of gear noise, but it's a CruiseDrive, it's noisy (compared to the S/E in the Night Train).
I always downshift when I'm slowing down and use both brakes. I didn't notice if the smell was stronger if I didn't do one or the other (I'll try that today).
Anyone run into this before?
Old Mar 21, 2010 | 09:19 AM
geezer glide 56's Avatar
geezer glide 56
I am going to guess it is from your free flowing air filter...I have a 2009 classic and I noticed the same thing after I altered the backing plate on my air filter...The crankcase vents through the heads into the breather...without an enclosed air filter those fumes escape into the air instead of being sucked into the engine.
Old Mar 21, 2010 | 09:27 AM
'05Train's Avatar
'05Train
It has the stock air cleaner.
Old Mar 21, 2010 | 09:33 AM
geezer glide 56
Hmmmmm....What do you clean the bike with?...Or perhaps it could be the new exhaust.
Old Mar 21, 2010 | 09:42 AM
'05Train's Avatar
'05Train
Same smell with the old exhaust. Thought it could be the converters. I use Meguires on both bikes, no smell from the 'Train.
Old Mar 21, 2010 | 10:08 AM
geezer glide 56
Perhaps being in the envelope behind the fairing and the lowers allows you to smell things you wouldn't smell on the other bike...Definitely strange...When you realize what it is I am sure it is going to be something simple.
Old Mar 21, 2010 | 10:12 AM
dswansbiker's Avatar
dswansbiker
Maybe one of your buddies slipped this in your gas tank as a joke. I know a few gals around here that use similar stuff.
http://www.jpcycles.com/product/900-497
Old Mar 21, 2010 | 10:18 AM
UltraKla$$ic's Avatar
UltraKla$$ic
Talking
Older Harleys left their "mark", the newer ones are much more politically correct and leave their "smell". LOL
Mine smells like refried beans when I ride after lunch.
Old Mar 21, 2010 | 10:40 AM
04 rkcrr's Avatar
04 rkcrr
UltraKla$$ic You are not right !!!!!
Old Mar 21, 2010 | 11:46 AM
'05Train's Avatar
'05Train
I'm thinking that I may have gotten brake fluid on the pads when I did the front end swap, and I'm smelling it cooking off.
