Max engine temp
Old Mar 21, 2010 | 11:43 AM
canuck pride's Avatar
canuck pride
Default Max engine temp
Just installed the in dash temperature gauge on my 09 EGC and was wandering what is the maximum temp that I should be looking for. Have no engine cooler. Thanks
Old Mar 21, 2010 | 11:57 AM
fireaxxe's Avatar
fireaxxe
It should be between typing "engine temp" in the search box and hitting the "Go" button next to it. There are waaaayyyy too many post on here in the archive for me to answer this question. This is your homework for the day.
Old Mar 21, 2010 | 12:05 PM
OnTheFence's Avatar
OnTheFence
230 - 235 on my 08 flhx at peaks. 220 most of the time.
Old Mar 21, 2010 | 12:16 PM
canuck pride
Thanks for the input. After installing this I found myself checking on it all the time. Wasn't sure if this was a good idea or not. And thanks for helping me on my home work.
Old Mar 21, 2010 | 05:06 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Talking
yeah, fireaxxe has been around here a long time, so he know his chit LOL LOL
Old Mar 21, 2010 | 05:10 PM
fireaxxe's Avatar
fireaxxe
Naw not that long only since November. I have learned that intelligence can speed up time...lol
Old Mar 21, 2010 | 05:26 PM
Sandcrab's Avatar
Sandcrab
Normal operating temperature is 230 degrees F per the manual. So if it is up to temp it should be around 230. However, what is above normal, do not know.
Old Mar 23, 2010 | 11:26 AM
flipbel's Avatar
flipbel
why do some members keep on doing this? it took fireaxxe 3 to 4 time more typing then it did onthefence to give out no information.
if you are not going to answer a question, then let it alone!!! imo
Old Mar 23, 2010 | 12:26 PM
Indianspringsaz's Avatar
Indianspringsaz
Probably because he didnt even know the answer )
Old Mar 23, 2010 | 12:40 PM
iclick's Avatar
iclick
"Normal" isn't necessarily optimal, and I wouldn't want my oil running 230° most of the time. As it is with a cooler installed I peak at 230° in summer traffic, hitting that only a few times per summer season, with normal temps staying around 200° while moving during the summer and 180° in winter. To me that's a good range that won't oxidize the oil very rapidly, as the hotter it runs above 180° or so the quicker it breaks down (oxidizes).
