Ape Flex???
Old Mar 22, 2010 | 07:57 AM
BostonBagger's Avatar
BostonBagger
Default Ape Flex???
Hey guys, looking to see if anybody else has this issue. Installed some yaffe Monkey Bars on my 08 Street Glide. They feel loose at the top. The clamps are tourqued correct. I was thinking since they are tall and wide that there would be some flex at the top. Should i take it apart and crank the bolts down? Does anybody elses have this movement on their apes? Thanks in advance.
Old Mar 22, 2010 | 09:21 AM
Xguy's Avatar
Xguy
change your bushing to Poly. gooden tite is one example of solid bushings.
Old Mar 22, 2010 | 10:30 AM
Beemervet's Avatar
Beemervet
Your '08 does have the one piece top clamp, doesn't it"
Old Mar 22, 2010 | 10:53 AM
Big Twi$t's Avatar
Big Twi$t
As mentioned...use poly bushings. Next, screw the recommended torque rating. Crank the bolts down, just MAKE SURE NOT to snap/strip them. And, get some skateboard grip tape and wrap around the bars before cranking them down. The '08s have a one piece top clamp so you are good there. Do all this and they won't budge!
Old Mar 22, 2010 | 06:10 PM
BostonBagger
Thanks guys, just ordered the Poly bushings. Try to get them on this weekend. Will update with results.
Old May 19, 2011 | 03:18 PM
cnnesseth's Avatar
cnnesseth
My tube which the grip goes on is coming loose contacted Yaffe but still waiting? Paid alot to install and have loosen up in just two months.
Old May 19, 2011 | 04:16 PM
Beemervet's Avatar
Beemervet
Start your own thread.
Old May 19, 2011 | 05:26 PM
2002EGlide's Avatar
2002EGlide
Just finished mine this past weekend. You will see a huge difference with new bushings. I did mine and upgraded to the one piece clamp. (02 was a two piece clamp) Solid as a Rock now.
Old May 19, 2011 | 05:40 PM
NoKenDo's Avatar
NoKenDo
Oh Beemervet.......
Old May 19, 2011 | 06:59 PM
Rammer's Avatar
Rammer
Default Flex
Isn't there gonna be a little flex? I added the 12" monkey bars and I have little flex in the bars when I brake. If this isn't normal let me know.
