possible problem in the making ?
Old Mar 24, 2010 | 01:31 AM
artz's Avatar
artz
Exclamation possible problem in the making ?
At 1am this morning I went outside to crank and warm up my carb'd '99 electra glide so I could come home from work. I did happen to notice as she was warming up that there was a little fog/condensation coming out of the throttle-side pipe, while the other exhaust pipe had no such indication. The temp outside was a slightly damp 47 degrees.
Anyone have any suggestions to what could be happening and is it something to keep an eye on for a future problem ?
Thanx...
Old Mar 24, 2010 | 02:48 AM
geezrglider's Avatar
geezrglider
If your headers are stock with - the crossover pipe - only one side is exhaust the other is a scavenger pipe. Would more than likley be the cause.
Old Mar 24, 2010 | 04:45 AM
imrotton2's Avatar
imrotton2
i wouldnt worry abut it,,,,,sounds normal
Old Mar 24, 2010 | 06:45 AM
rdam's Avatar
rdam
Normal. Put your hand behind the exhaust on each side and you'll "feel" how little comes out the left.
Old Mar 24, 2010 | 06:53 AM
captjon37's Avatar
captjon37
I have true duals and never noticed it before i chromed the tips but when i crank it up now i can see that inside the tips the condensation dancing on the walls in the tips. The humidity has a lot to do with that effect.
Old Mar 24, 2010 | 12:54 PM
artz's Avatar
artz
Thanks all ! All your answers make sense. One thing that I did that night before I rode off into the cool of the morning, was to put my hand behind the exhaust to feel the pressure and I did notice the left exhaust wasn't as strong as the right one.
Thanks again.
Old Mar 24, 2010 | 01:36 PM
flhtupser's Avatar
flhtupser
Warming the bike up before a ride is fine. Some folks start up their bikes during the off-riding season and let them run a bit ,then shut them off. Doing this promotes condensation inside the case which is not good. So in short, only start her up before a ride and ride enough to bring her up to operating temp and all is fine. My 2 cents.
limeyhusker
EVO
16
Oct 2, 2014 07:45 PM
narfical
Exhaust System Topics
May 19, 2014 04:18 PM
rickydog
May 27, 2011 12:39 PM
tumbleweed883
Apr 15, 2009 04:02 PM
relli
Nov 10, 2007 08:11 PM
