not sure about this
Old Mar 25, 2010 | 01:17 PM
bocajube's Avatar
bocajube
4th Gear
Default not sure about this
Newbe to things here...I have a situation with reinstalling same (newly wrapped) baffles into pair of Bassani mufflers. One lined up right on the bolt hole....the other....well....it got jammed up tight and is about 1 inch short of ligning with the bolt hole.....does the baffles have to be inserted the same depth....if not will this cause problems with back pressure.
Much thanks for any help....I'm really not wanting to have to buy new mufflers.
Boca
Old Mar 25, 2010 | 01:41 PM
ICIBUY's Avatar
ICIBUY
Wow, good question! What year and model bike? Maybe someone else has had this happen and have an easy fix! BTW... welcome to the forums!
Old Mar 25, 2010 | 02:30 PM
bocajube's Avatar
bocajube
4th Gear
2003 rkc
Old Mar 25, 2010 | 02:32 PM
bocajube's Avatar
bocajube
4th Gear
as of now my only option that I can come up with is to remove the "rightly" installed baffle and insert it the same depth as the jammed one and drill new bolt hole
Old Mar 25, 2010 | 04:01 PM
JackieGrier007's Avatar
JackieGrier007
Default Tight baffle install
Just run the bike and get the slip on good and hot and the baffle that was tight will just slip in !...Remember metal expands with heat ! I would be willing to bet it will slide right on in !....Good Luck
Old Mar 26, 2010 | 09:47 AM
bocajube's Avatar
bocajube
4th Gear
thanks...I'll give it the ol' heat treatment and see what pops up....and hopefull out.
T Man
Jun 10, 2017 06:06 PM
Stang951
Exhaust System Topics
Jun 25, 2015 12:05 PM
Steel Steed
May 5, 2012 04:39 PM
bikerdog134
Jul 24, 2007 01:02 AM
jerseyjeff62
Jun 7, 2007 10:57 AM
