Mixed Brake Fluid
Old Mar 28, 2010 | 11:45 PM
  #31
troy.j's Avatar
troy.j
i rememner dot 5 being amber in my 88 heritage....
Old Mar 29, 2010 | 12:29 AM
  #32
hot95hog's Avatar
hot95hog
Why worry about what is in the system, flush the whole thing with DOT 5 and be done. if there was any mixing it wasn't in there long enough to do any harm. Flushing are refilling and bleeding with DOT 5 will answer your problem, and you will also know when the system was last serviced.
Old Mar 29, 2010 | 06:00 AM
  #33
Taterdog's Avatar
Taterdog
Gotta be dot 5 after all. I poured some of the old fluid in a bottle of water last night and it floated to top -- wouldn't mix at all. Then poured some of the new dot 5 purple fluid in a bottle of water and it did the same. Then mixed the old fluid and new dot 5 in another container and they mixed perfectly. So, after all that, it's dot 5. At least now I know HOW to check for the stuff. Can't go by color alone.
Thanks everyone.
Hot95hog, I've got some speedbleeders on order. Once they're here, I plan to bleed it all with fresh dot 5 anyway, so should be good no matter what.
chromepony
General Topics/Tech Tips
Feb 16, 2015 09:16 AM
K&L cycles
Mar 14, 2014 10:12 AM
oitsbarb2455
Ironhead
Mar 16, 2012 12:07 PM
Weed's Ironscoot
May 6, 2010 12:06 PM
dobeman21
Sep 10, 2008 08:44 AM
