Improved MPG
Old Mar 30, 2010 | 05:59 PM
Sancho's Avatar
Sancho
Default Improved MPG
I installed a switch on my PCV to take advantage of running 2 maps.
Yesterday I received a map from Jamie at Fuelmoto revising my original map to be run as the #2 map for improved mpg.
I installed it as the 2nd map and tested it this morning riding 59.1 highway miles on the revised map. About 3 miles of the 59 was stop and go traffic.
20 mph tailwind 1/2 through the trip then a 20 mph headwind returning.
70 mph cruising speed with cruise control on.
75 deg outside air temp
209 deg oil temp
refilled at the same gas staion upon returning
45.45 MPG
The best I've gotten with the original map is 38 MPG.
The bike ran just fine and I couldn't tell I was running on another map.
I have a stock 96", D&D Boss Fat Cat 2:1, Ness Big Sucker, oil cooler, synthetic oil.
__________________
Good judgment comes from experience, and a lotta that comes from bad judgment
Old Mar 30, 2010 | 06:25 PM
XRider's Avatar
XRider
That is a significant (about 20%) improvement. Tell those of us with a PCV about the switch you installed.
Old Mar 30, 2010 | 07:01 PM
will2002's Avatar
will2002
Now that is something I could really use!
Old Mar 30, 2010 | 07:24 PM
Sancho's Avatar
Sancho
Here is a thread about installing the switch.
https://www.hdforums.com/forum/elect...ng-2-maps.html
Old Mar 30, 2010 | 08:00 PM
redhwk44's Avatar
redhwk44
Good info
Old Mar 30, 2010 | 08:06 PM
MNPGRider's Avatar
MNPGRider
The RideMaxx has that feature....
http://www.americanmicrofuel.com/ridemaxx.php
Old Mar 30, 2010 | 08:43 PM
papifun's Avatar
papifun
i did my two map mod over winter. will test finally this weekend when scoot will wake from the long winter !!..
Old Mar 30, 2010 | 08:48 PM
flhtupser's Avatar
flhtupser
Can the 2nd map function be used on a pcIII?
Old Mar 30, 2010 | 10:49 PM
Sancho's Avatar
Sancho
No. But, I understand Jamie has a retrofit so that a PCV will fit on an '07 or '08 bike and will provide the maps.
Old Mar 31, 2010 | 07:16 AM
skratch's Avatar
skratch
there is a hub that you can get that will allow you to do that, but i think that it would be more advantageous to get the retrofit kit for the pcv.
