Replace gasket???
Old Apr 3, 2010 | 12:01 AM
brino's Avatar
brino
Default Replace gasket???
Do I need to replace the gaskets every time I change the oil or is this just HD trying to get more of my money?
Old Apr 3, 2010 | 12:13 AM
cfdcaptain99's Avatar
cfdcaptain99
I feel your pain. I just replaced my primary chain tensioner shoe. $5 for the shoe, $32 frickin' dollars for the primary gasket. What a rip! I figured it was cheap insurance versus having a leak and adding another $8 for another quart of oil.
Old Apr 3, 2010 | 12:15 AM
cfdcaptain99
BTW. Welcome to the Forums!
Old Apr 3, 2010 | 12:39 AM
hog-doc's Avatar
hog-doc
Which gasket?
If your talkin about the O-ring on the drain plug you can just inspect it, if its still nice and round, clean it reoil it and reuse it. If its torn or ragged replace it. If you oil an o-ring before installing it they tend not to get torn up as fast and will last several uses.
Old Apr 3, 2010 | 01:12 AM
xxxflhrci's Avatar
xxxflhrci
Spending 32 bucks to possibly save 8 doesn't compute..LOL...In my experience, the primary cover gasket is good for more than one use.
Old Apr 3, 2010 | 02:29 AM
Bamm Bamm's Avatar
Bamm Bamm
1st Gear
Default Cash grab
Having worked as a tech for HD for some years and having performed countless oil changes I can officially state it's in your motorcycle's best interests to change the oil ring every time it's accessed. Having said that, unofficially, it's strictly a cash grab as it's reusable until it shows visible signs of deterioration. HD has and will continue to charge it's customers as much as the market will bear. It's just a fact of life.
Old Apr 3, 2010 | 06:01 AM
emwolb's Avatar
emwolb
i change the o ring each time. i figure if i didn't catch a crack or tear, i'd end up having a drip until i replaced it. fifty bucks worth of oil being jeopardized for the cost of an o-ring? to me, that's a no brainer. i always cut the old one so it cannot be re used, although i have stashed a few of the ones which look to be in pristine condition, just in case.
Old Apr 3, 2010 | 06:12 AM
Notgrownup's Avatar
Notgrownup
I change my O-ring about every 3rd change...i am still on my original Primary inspection cover gasket at 43000. never had a drip...o use a little pipe dope on my drain plugs every time...Acts as a anti seize also...Pretty cheap to do so though but HD will try to sell you one everytime...
Old Apr 3, 2010 | 06:16 AM
Iceman24's Avatar
Iceman24
Personal preference - as you can see from others. I'm in-line w/the "3rd time's a charm" responder - swap every 3rd change. Cheers!
Old Apr 3, 2010 | 08:05 AM
brino's Avatar
brino
Thanks guys... I kinda thought that changinig them every time sounded odd.
