Dual Pipes Need Dual Dyno?
Old Apr 3, 2010 | 02:46 PM
Sp0rtster's Avatar
Sp0rtster
Default Dual Pipes Need Dual Dyno?
Can anyone speak to the theory that if a bike has true dual exhaust, then to maximize performance and tune, both pipes should be sniffed by the dyno to achieve some sort of "balance"? I've heard dyno guys claim it doesn't really matter because the tuner/ Power Commander adjustments made will affect both jugs. I've also heard from different dyno guys that with a true dual system, both pipes need to be individualy tested and mapped for maximum performance. Both arguements seem plausible if not convincing, or is one just a marketing scheme by a shady dyno tech? Interestingly, the PCIII software DOES have the ability to map both pipes separately.
Old Apr 3, 2010 | 03:22 PM
hog-doc's Avatar
hog-doc
Anytime you run true duals your dyno guy maps each cylinder individually. The auto tunes read the O2 sensor in each pipe and make adjustments based on those readings.
Cobra231
Exhaust System Topics
Sep 7, 2015 07:10 PM
Buck Lovell
May 28, 2014 09:35 AM
jjr
Jun 15, 2007 10:40 PM
rscott82
Jun 8, 2007 06:50 PM
asuperheat
Aug 27, 2006 12:25 PM
