Hey guys, just picked up a Craftsman Professional series motorcycle jack to jack up my '08 Ultra for cleaning and primary change. After trying it out this afternoon, it seems that, even with the jack as far back as possible (right in front of the rear crossmember) that the bike is still unbalanced-heavy in the rear. Can't move the jack back any further because of the crossmember, and then right behind the crossmember the frame curves upward.
Where are you guys putting the jack for the best balance? Or are you just putting a strap over the front half to keep from tipping back?
Any tips would be appreciated
I bought the Craftsman jack, tried it on my bike and promptly returned it. I went with the J&S and it works great. Well worth the money. My bike is always steady and I have no worries when it's in the air.
Wow--thanks guys. Thought I researched this enough before I bought--guess not.
So, is anyone using the Sears jack with good results?
I did spend a little more and got the Professional series because I read lots of bad reviews on the cheaper Sears version. I just assumed that it would fit OK.
Unless that crossmember fits inside the jack, it will never balance properly...(my experience).......so return the Sears Yellow & buy one of the jacks the other fellas suggested.
So what the heck do you guys mean by "in the crossmember". All I do is roll my jack under the bike so it is as far back on the frame as possible and then jack it up and never give a 2nd thought about the crossmember.
