CRAPPY SEARS JACK! (the red one)
Old Apr 14, 2010 | 10:36 AM
watercop's Avatar
watercop
I've had mine 4 years and do most all of my own maintainence. I also put my RKC on the stand to wash and wax. No problems. I know in in our area we have independen hydraulic parts and reapair places. Perhaps one of those guys could help. I definitly would not leave a bike on the jack over the winter without at least letting the weight rest on the mechanical stop
Old Apr 14, 2010 | 11:29 AM
mainshaft's Avatar
mainshaft
Going on 9 years with my Sears jack in a un heated garage, no issues to date. I use it all the time.
Old Apr 14, 2010 | 12:31 PM
redscout's Avatar
redscout
I've had 2 of 'em for quite a few years and neither has been a problem. Must not be the same now as they used to be since my bottle jack isn't welded to anything. I have even taken it off to use on a bad car door to level it up.
Old Apr 14, 2010 | 01:05 PM
skratch's Avatar
skratch
Originally Posted by faapilot
J&S Jack the only way to go....well worth the $$$$..
No issues
and j&s uses the same imported bottle jack that the others use......
Old Apr 14, 2010 | 01:23 PM
cosshog's Avatar
cosshog
7 years with mine no problems. Use it on a regular basis and my garage is not continuously heated.
Old Apr 14, 2010 | 01:53 PM
DocHarley's Avatar
DocHarley
B-day present 6 years ago not one issue.
Old Apr 14, 2010 | 04:23 PM
Badbagger's Avatar
Badbagger
Had my red Sears jack for well... a LONG damn time and NO issues. Must not have been made on a Mon or a Friday lol... No complaints
Old Apr 14, 2010 | 04:27 PM
TheDon81's Avatar
TheDon81
I've had mine for 5yrs without an issue, stored in a unheated garage, and use it for everything from oil change to cleaning the white walls.
Old Apr 14, 2010 | 04:31 PM
RandyDowdy's Avatar
RandyDowdy
Any forklift or hydraulic shop can get you the seal kit for little of nothing. Not hard to repair either. Good luck!
Old Apr 14, 2010 | 04:55 PM
iamrfixit's Avatar
iamrfixit
Sounds like you need to bleed the jacks pump unit.
Open the lowering valve and pump the lifting pedal a few times, then close the valve and see if that helps.
You also might check the oil level in it. Most bottle jacks have a rubber plug on the side and the oil level should be up near the plug with the jack lowered and setting vertical.
If that doesn't work you should be able to replace the bottle jack fairly easily, unfortunately it will likely be with another cheap chinese piece of garbage since that is all you can find these days.
