fairing brackets
Old Apr 18, 2010 | 08:16 AM
n8dc's Avatar
n8dc
Originally Posted by Scorpion07
The updated version of the HD fairing brackets are a bit more robust. I had them replaced under warranty last year. Time will tell if they solve the problem?
Prior to that I fab'd my own end piece once, as you are. It held up perfect.
Check J & P Cycles. I know Iv'e seen the end piece with rubber bumper in their catalogue. Not cheap though (around $25) which would put you close on price to HD's upgraded version.
One thing I've noticed with the upgraded brackets (I have all 4), a bit more vibration in the mirrors & wind deflectors. I firmly believe that's the real reason they never changed their design until now. The old design had perfect harmonics, at least until it failed.
Thats prolly why im seeing a bit more vibration at certain rpm's because mine is more solidly mounted now after I welded the brackets like they should have to begin with . Since im still out of work and have a lot more time than money I decided to just do the welding on mine for now ..
Old Apr 18, 2010 | 08:39 AM
andyp's Avatar
andyp
There is a company that makes rubber isolators ,its called savior,about 30 bucks.I have read in these forums they have been used with good results.
Old Apr 18, 2010 | 09:01 AM
leadman's Avatar
leadman
I think I'll go ahead & use the aluminum angle for now as that is what I have here. I'll
look at work & find some steel to use later if the aluminum breaks.I'm sure not about
to spend $90.00 on brackets to repair something H-D designed wrong.
Old Apr 18, 2010 | 11:51 AM
FastHarley's Avatar
FastHarley
Former Sponsor
Default broken bracket
Just took the outer fairing off of a 2008 and found the right side 90* tab broken. I wounder how many are out there like this?
Old Apr 18, 2010 | 01:14 PM
mike5511's Avatar
mike5511
Here is the link to the Savior bracket.....doesn't look like it would be too hard to fab it at home.
This looks like it would be the best solution to answer increased vibration after strengthening the current brackets.
http://www.savior250psi.ca/QuickRepair_about.html
Old Feb 3, 2011 | 11:37 PM
Joer5000's Avatar
Joer5000
Stage III
I broke the lower fiber glass tab off on my front fairing is their a way to attach it so it stays, It is the Fiber Glass mount with the brass bushing on inside of the front fairing, pissed me off i just had it painted!
Old Feb 4, 2011 | 06:19 AM
cochon's Avatar
cochon
Geez, Leadman, I don't think that i'd use that aluminum angle. Aluminum is very soft and malleable. If you tighten a bolt on it and the fairing wants to move around (vibrate) the bolt will just wear into the aluminum.Then, you will have a "loose" bolt. I'd spend the extra couple of dollars and buy a small piece of angle iron, or, if you want to splurge, stainless angle(no rust).
Old Feb 4, 2011 | 12:59 PM
flhrbill's Avatar
flhrbill
Looks like a great weekend to take my fairing off. I have an 09 EGC with 27,000 miles, but I'm not sure if I have the newer style brackets. I haven't noticed and difference in the way she handles or vibration in the fairing but since it only takes five minutes to take it off, I'll give it a look.
Old Feb 5, 2011 | 01:48 PM
flhrbill's Avatar
flhrbill
Spent 15 minutes this morning taking the fairing off. No broken brackets but I went ahead and replaced the two longer brackets with the new and improved design. For $20 bucks it was worth doing.
Old Feb 5, 2011 | 02:00 PM
Jim Dawson's Avatar
Jim Dawson
I repaired mine with steel brackets from Ace Hardware a year ago. They seem solid as a rock now.
