it should be in the wish book - and it takes several parts to do this - also if you plan on doing it your self - be prepared - its a tough one, do a search here, there are several post about this. at the moment I do not have access to the books
Talk to the parts guy at your dealership, their computer tells them everything you need. You'll have to buy it from them anyway, so you might as well make them look it up. Once you get it, be prepared for some frustration. H-D directions usually leave something to be desired, but the ones for docking kits are particularly tough because there are different docking kits and the one you want depends on what you want to dock. (For instance, your tour pack won't use the same docking points as a passenger backrest, so you have to get the right one.) If you know someone with the docking kit installed, it would definitely be worth the time to take some closeup pics of their installation to help guide you.
My advice is to buy from Zanotti's or Benjy's or Hales for 20% discount on all parts. Also, check out the forums for antenna mods since the HD P/N 76326-00A (Antenna Relocation Kit) is a box of stuff you can buy locally for a fraction of the cost Harley charges.
Also, disregard HD alerts in the catalog which say the docking kit (above) will not work on your bike. Those parts work great and the catalog has messed up again.
