Cruise Control Quit Working
Old Apr 18, 2010 | 10:42 PM
ElectraLarry's Avatar
ElectraLarry
Default Cruise Control Quit Working
Last week I noticed my cruise was not staying on, it was very touchy and would come off when I hit a bump. Today it wouldn't work at all, the light stayed red and would not take a set. This is a factory installed cruise on an 06 EG Standard. I recently had both tires replaced and some minor suspension work done - would that effect anything?
Old Apr 18, 2010 | 11:25 PM
MikeyTX's Avatar
MikeyTX
Could be a bad brake light switch. All I have to do is barely touch my brakes to disengage my cruise.
Old Apr 18, 2010 | 11:50 PM
EricD10563's Avatar
EricD10563
I second that my cruise control stopped working and the following day my rear brake light switch failed.
Old Apr 18, 2010 | 11:57 PM
MikeyTX's Avatar
MikeyTX
If I had a dollar for every time I've been behind another hog rider with their brake light burning bright red and the rider never knew it .......................
Old Apr 18, 2010 | 11:59 PM
dabluesguy's Avatar
dabluesguy
Seen it happen twice. Guys kept sayin' "My cruise quit working".
Old Apr 19, 2010 | 12:36 AM
blue4774's Avatar
blue4774
It might be the contacts in the switch. I shot some WD 40 into the switch, solved my problem.
Old Apr 19, 2010 | 12:54 AM
Dustball's Avatar
Dustball
Check your Roll On switch on the throttle cable (right side frame by the neck). Disconnect the connectors and try it. It's a pretty common failure. With the switch disconnected, cruise will function normally, and any brake application or clutch pull will cancel correctly. *Throttle inputs will NOT disengage the cruise with the Roll On switch disabled, so be careful...
Old Apr 19, 2010 | 01:33 AM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
Thunder stolen...check "disengaging switches"; F/R brakes, clutch.
Old Apr 19, 2010 | 03:16 AM
rocketmanalien's Avatar
rocketmanalien
E.L. just got my bike back from dealer ck engine light stayed on and no cruise pi$$ed me off on the end of a 300 mile ride the problem was the fly by wire in the grip after they replaced it seems to be more responsive than it was hope that don't happen again love that cruise good luck with problem
Old Apr 19, 2010 | 04:54 AM
RodeDawg's Avatar
RodeDawg
Roll Off switch on the neck of the frame. Pull the contact wire from there. Just remember that you can't disengage the cruise by rolling bak the throttle any more. This is the solution 80% of the time on these.....
