throttle grip problem
Old Apr 19, 2010 | 11:10 PM
09sungloflhx's Avatar
09sungloflhx
Thumbs down throttle grip problem
i just put a set of pm grips on my sg and no matter what i do to the throttle grip it gets tight like its binding not always though i screwed with ot for an hour and nothing i do makes it better what the hell gives i new the problems started when i coulnt get the switch caps apart i had to loosen the master cylinder mount to spread them apart enough to get the rib out so do i need to get different gribs or is there something else to adjust its not tight to the handlebar its like the grip is to loose over the bar allowing it to move a little to much csausing it to bind?
Old Apr 20, 2010 | 12:31 AM
hog-doc's Avatar
hog-doc
Probably just need to move the master and switch housing towards the end of the bar a little. There needs to be a little free play for the grip in the switch housing.
Old Apr 20, 2010 | 09:16 AM
09sungloflhx
ive tried moving it in or out no help gte worse the it get stiff if you dont turn the grip perfevtly if you lift or pull on the grip when turning is stick its loose on the bar at the housing? hard to explain
Old Apr 20, 2010 | 09:25 AM
Leftcoaster's Avatar
Leftcoaster
Hard to understand, too.
Old Apr 20, 2010 | 10:19 AM
IceHeritage's Avatar
IceHeritage
I had the same problem when i changed my Grips and to resolve the Issue I did exactly as hog-doc said you have to pull the master out a little and twist it a little forward or back.
Old Apr 20, 2010 | 03:09 PM
09sungloflhx
Angry
ill try and screw with it again tonight maybe i was so dam frustrated i gave up i screwed with it for over an over moving everything it seems like the simplest thing can be the biggest pain in the ***
Old Apr 20, 2010 | 03:40 PM
VETERAN75's Avatar
VETERAN75
sounds like something is just not quite right. Maybe take it all off that side or at least loosen everything and set it back up. There may be some trash or something that got in between the bars and the twist grip. make sure it's clean.
Old Apr 21, 2010 | 01:33 AM
09sungloflhx
i tried moving it out it got worse moving it in made it better can someone with pm grips tell me if their throttle grip moves up and down a bit by the controls thats when it binds its loose if not i am gonna get some different grips cause this is rediculous i cant believe how much bs it is to change grips that i paid 150 dollars for
Old Apr 21, 2010 | 07:32 AM
r8rs4lf's Avatar
r8rs4lf
I have a set of PM rental grips on my '09 FLHT. I had the same problem having to split and move the housing to get my factory ones off. However, I don't have a binding problem. I do have a slop problem. There is a lot of slop after I installed those grips. They work well, no binding, but the amount of slop up and down at the housing is just crazy.
Old Apr 21, 2010 | 01:15 PM
09sungloflhx
Thumbs down
exactly there is to much slop if i continue to have problems i m gonna shave that rib thats binding a little thinner i see no way to fix it now due to the movement it binds if you lift up on the grip to much while turning as far as im concerned for 150 bucks they are junk what a joke
