Which gas do you use?
Old Apr 21, 2010 | 05:51 AM
electra glide jim's Avatar
electra glide jim
Default Which gas do you use?
I got a used RK 04 custom,and don't have an owner's manuel?What octane gas should I be using?
Mikuni carb,bassini true duals, K&N air filter,otherwise stock.
I have put 300 miles on using hightest.
Jim
Old Apr 21, 2010 | 06:24 AM
todd-67's Avatar
todd-67
You will get an array of answers here. You can run about anything in them as long as your not pinging. The newer models recommend 92 or higher.
Old Apr 21, 2010 | 06:39 AM
Mevman's Avatar
Mevman
My '04 Ultra manual says 91 or better.
Old Apr 21, 2010 | 06:44 AM
audettd's Avatar
audettd
I'd use 92 or higher
Old Apr 21, 2010 | 06:46 AM
Road Ranger's Avatar
Road Ranger
Around her 92 is high as they go at the pump unless you buy a racing fuel like turbo blue.
Old Apr 21, 2010 | 06:55 AM
slime_dog's Avatar
slime_dog
If your engine is not built and tuned for high octane fuels, running higher octane fuels will result in lower power and increased emissions. The post that said use as low an octane as you can without engine pinging is right. I mostly run 89 octane with no problems. On hot days when I am moving slow, like at rallies, I will up the octane to 92 or so.
Old Apr 21, 2010 | 07:02 AM
shortride's Avatar
shortride
I use Shamrock 93 octane fuel locally. My '07 RKC and '09 Ultra Classic owners manuals recommend 91 or higher octane. I read a post a few days ago where some was using 87 octane and said it ran fine. I don't believe that. He may just think it's running ok.
Old Apr 21, 2010 | 07:10 AM
fireaxxe's Avatar
fireaxxe
I like the shell 93 octane and I use a fuel additive in case the fuel is a bit lower than rated. The manual says 91 at a min tho.
Old Apr 21, 2010 | 07:15 AM
ken thompson's Avatar
ken thompson
The Schlong Man
I use premium. Have run mid-grade a few times with no obvious differences.
Old Apr 21, 2010 | 07:21 AM
SixSixRider's Avatar
SixSixRider
I use "premium" exclusively in my '09 FLTR (and my wife's '09 FLHX) and have never had ANY issues under any riding conditions. What's "premium" can vary from station-to-station - typically either 91 or 93 octane.
