Chain case oil
Old May 1, 2010 | 06:12 PM
n8dc's Avatar
n8dc
10 w 40 non syn or ATF.. save your money .. Mobil 1 v-twin is a big waste for the primary . I just changed to Mobil 1 15w50 from walmart.. Get 5 quarts for A lot cheaper than the v-twin stuff and it works fine in the engine .. After 4 more changes ill get a free one with the extra quart each time..
Old May 1, 2010 | 06:52 PM
Moonrider's Avatar
Moonrider
Originally Posted by hawg50
b&m trick shift automatic trans fluid type f is a good alternative.most of the racers in top fuel and funny car use it in their clutches.
Its what I use and the lighter oil helps to slightly lower the primary temps.
Old May 1, 2010 | 08:17 PM
07RoadHawg's Avatar
07RoadHawg
I recently gave in and did the switch to Type-F ATF. Nice smooth engagement, no slipping. Plus O'Reilly had Valvoline Type-F on sale for around $2.50 per qt IIRC. Can't beat that... I'm sure B&M is good oil, but it's a Type-F ATF (printed on the label) and at about $7 per quart is a little pricey for my application. Formula+ had been working well for me and I had no reason to change other than I just can't leave anything alone and I like saving money when it's practical to do so.
Like others have said, the oil provides lubrication to the chain and a bearing, but it's main function is to keep the clutch pack cool. Just seems like a thinner oil would cool better and still provide adequate lubrication at the same time. WTF do I know though...
Old May 1, 2010 | 09:18 PM
dan11809's Avatar
dan11809
Originally Posted by hawwk
The 80w is to heavy for the chaincase save it fot the trans. Get some atf or motor oil and use it.
Just my .02 cents
Don't use the Redline 80 weight in the trans,use the Redline V-Twin it's 90 weight. This is right off Redlines website.
Old May 1, 2010 | 11:07 PM
Route66rider's Avatar
Route66rider
Default Primary chaincase oil ?
Thanks to all for the info. Since the weatherman just forecast 10.3 inches of rain for tomorrow I don't suppose it matters a lot right now anyway. I will drive to the local NAPA or Autozone store tomorrow afternoon & see what they have to offer. Monday & Tuesday are about the same, but Wednesday onward is supposed to be good weather...
Old May 2, 2010 | 09:06 AM
1flhtk4me's Avatar
1flhtk4me
Might want to take your boat!
Old May 2, 2010 | 09:25 AM
Lost1's Avatar
Lost1
I use a mix of Formula+ & Rotella 15W-40. My primary takes 38 oz, so it gets a quart of F+ and I make up the difference with Rotella. I've tried several different (and more expensive) oils and this combination gives me the best clutch feel. Many just run straight Rotella, so I may give that a shot next time around.
There are lots of options out there that don't cost $10+ a quart- dino engine oil, Rotella, regular ATF, & Formula+ are just a few. Try different ones & see which gives you the best clutch feel...
Old May 2, 2010 | 09:52 AM
Apex Rider's Avatar
Apex Rider
I've used Syn3 or F+ in the Primary for 40k miles. Until 3.5k miles ago I switched to Rotella.
Clutch action has never been better.
Old May 3, 2010 | 12:22 PM
GSlone's Avatar
GSlone
Default Primary Oil
I also use the Redline V Twin Primary oil in my primary.
Old May 3, 2010 | 01:52 PM
Leftcoaster's Avatar
Leftcoaster
Dexron ATF in the primary. Cheap, easy to find, and effective.
