Handling Characteristics of Large Wheels
Old May 2, 2010 | 09:25 PM
BlackFLHR's Avatar
BlackFLHR
Default Handling Characteristics of Large Wheels
My dad has a 2008 Anniversary Edition Ultra Classic. It has a 21" front wheel (not sure what size the rear is, but it matches the front). It is a laced wheel, but I don't know if it was "stock" for the anniversary edition or if the dealer added it. I can only guess that it came from the factory with these wheels, as the spokes are color matched to the anniversary paint.
Anyway, the bike has a wobble at any speed above 40-ish. I checked and adjusted the steering head bearing. It was already ok, but I tightened it so it would be on the tight side of spec. The bike also has a True-Track on it, which was installed at time of purchase.
I inspected both front and rear wheels for any "play" in them, but everything checks out ok. I looked over the frame for any cracks, but again everything looks ok.
So that brings me to my question... Is this wobble maybe just a character of a large wheel? I've never ridden a bike with 21" wheel, so I'm not sure.
Old May 2, 2010 | 09:37 PM
103Eagle's Avatar
103Eagle
If a wobble was part of the 21 package, they would not sell many of them. Plenty are sold as are 23 and 26 to the extreme. You said they were spoke wheels. I would check to see if the spokes are tight as they can loosen over time. Next I would check for broken motor mounts and next check for play in the swingarm cleve blocks. Sounds like you have a problem somewhere and may be a safety issue to ride.
Old May 2, 2010 | 09:57 PM
highwayman1224's Avatar
highwayman1224
An ultra ain't coming outta the factory with a 21 on it.
Old May 2, 2010 | 10:56 PM
BlackFLHR's Avatar
BlackFLHR
I forgot to add that the bike inquestion only has 700 miles on it.
Old May 3, 2010 | 12:20 AM
bagman1's Avatar
bagman1
as mentioned, check the spokes and check wheel balance. Personally I dont like 21s on a bagger for looks and Im willing to bet a bagger with 2 up is exceeding the load rating of the front axle. The bike is too heavy to have something that light on the front end. JMPO
Old May 3, 2010 | 04:40 AM
'05Train's Avatar
'05Train
A larger wheel will exaggerate any imperfection (like an out of round situation) in the wheel. They're also generally heavier, which means more unsprung weight, which means poorer acceleration, braking, and handling.
A wobble isn't a characteristic of a larger wheel, but a larger wheel will negatively affect ride and handling with less wrong with it than a smaller wheel.
Old May 3, 2010 | 05:56 AM
JustDave71's Avatar
JustDave71
I used to have a bit of shimmy in the front...had the wheel checked...out of balance and a handful of spokes a hair looser than they should have been. Took care of those two issues for complete elimination of wobble.
mshred
Jun 5, 2019 01:54 PM
No U Glider
Wheels/Tires
Jul 20, 2017 07:30 AM
FFeric
Jul 19, 2015 07:57 AM
mrvet60
Welcome Area Only
11
Jun 14, 2010 02:42 PM
BigDaveOnBass
Dec 25, 2009 07:32 PM
