Fork Oil Change Made easy
The discussion of the switch removal is because it is required for the job and can be tricky if you don't do it right.
Removing the switch (which some are doing) in the "off" position is okay but when you want to reinstall the switch, it has to go in on the "lock" position. When doing so the switch will be locked down but the tumblers will not be in the lock possition.
Like my father says, "there's a hundred ways to get home, just pick a route your comfortable with."
Or am I missing something here? This way I don't need the tool and if I am removing the ignition assembly I'm sure it's because I just need to remove the cap.
So, put switch in lock position with forks straight, remove ignition, remove cap, put ignition back in. Won't that work?
I don't want to hijack rshwetz's thread but this is why.
Look at the switch. You can see there are only two cams that turn the tumblers. The switch needs to be spaced just right or it will only turn one tumbler (upper or lower). It could even turn one and lock the switch down in there. You would then have to turn it until you got it out. Doing this may get them out of whack. I made the video for the guys that aren't as mechanically savvy, wanted a little confidence, or just wanted to see how it came out. You dont have to make the tool. You can just remove the spring, the spacers, locking nut so you can get to the cap. Then reinstall it all to space the switch out right. Then take it all back apart to install the cap when the job is done. Most people made the tool for under $1. So, the .99 question is why not make the tool? Here is the thread I started with the video https://www.hdforums.com/forum/touri...h-removal.html
As I said, I just remove it in the LOCK position while the forks are pointed straight, then do my work and re-insert the **** in the same position. Works every time. But what I don't understand is how your bike's lock failed in the video after doing this and moving the forks to the locked position and back after the **** was removed. When you did this the lock didn't work. I haven't tried that with mine and don't really want to, but maybe the rule of thumb is to keep the forks away from the locked position if you do it my way.
So if I do it my way and accidentally lock the forks, I should be able to re-insert the **** (with spacers and nut in place) and unlock it, right?
To Hogdoc: When you remove the switch in the ACC position do you re-insert it in the same way?
What I'll probably do the next time is replace them with a regular hex-head bolt, then put a chrome cap on it. I used these on my old RK and it worked well, but you need to be careful not to over-torque the bolt, as you have a shallow bolt going into aluminum and it would be very easy to strip it. OTOH a button-head Allen would work well too. Did someone say they found these at their HD dealer? If not, Ace Hardware would probably have them in chrome. Does anyone know the thread size and pitch? The parts manual does not have this information in the back section where it should be.
As for forks on the newer models, I've never understood the reasoning behind the elaborate procedure HD outlines in the service manual, but Hogdoc suggested it might be to allow inspection of the bushings. Mine never wore noticeably even after 100k miles in my old bike, but I guess they could wear and damage the slider. My write-up and this thread show how to do a fork-oil change that takes about an hour and requires little fuss.
