whit brake
Old May 9, 2010 | 11:46 AM
KingCripps's Avatar
KingCripps
Definitely an accident waiting to happen. They are combining two things that should not be put together.
Old May 9, 2010 | 01:00 PM
MarineBagger's Avatar
MarineBagger
I wouldn't use it personally, but I have a buddy who is an amputee below his right knee. He is considering getting one because he can't lift his prosthetic foot to operate a normal brake lever, but he can push his whole leg down and forward to operate this sort of brake. His other option is some sort of system where the front brake lever operates front and rear brakes. Any suggestions?
Old May 17, 2010 | 08:49 PM
buggin02's Avatar
buggin02
If you will remember, Harley used that design on some of the old flatheads for operating the foot clutch on the left footboard.
I am sure they had a good reason to stop.
Old May 17, 2010 | 09:21 PM
dawg's Avatar
dawg
Click HERE for a website that has links and suggestions for just about any modification to assist.
Old Sep 9, 2010 | 11:47 AM
Road_King_Rider's Avatar
Road_King_Rider
Talking Whit brake
Originally Posted by bruce sg08
Anyone see the new whit brake www.whitsbrake.com in the new issue of Hot bike baggers? Web site doesn't have much info, will you still be able to use the whole floor board with out the brake coming on? Any one planning to be the genniea pig?
I've ordered one and just waiting for it to arrive. I'll post back once I have given a try out.
Old Sep 9, 2010 | 12:17 PM
Aleslinger's Avatar
Aleslinger
Sounds like a linked braking system would help people who can't really use the rear breaks. For those who shift weight in the turns this new breaking system would not work. I put pressure on my boards when I make sharp low speed turns (Ride Like a Pro) and this will not work for me. I guess it would be good for people who think the break lever is in the way.
Let us know if anyone gets it and how it works for you.
Old Sep 9, 2010 | 12:44 PM
Badfinger's Avatar
Badfinger
Technically speaking, if you only change the rear brake doesn't that make it a Half Whit brake??
Old Sep 9, 2010 | 01:06 PM
El Rey's Avatar
El Rey
It's called a Rocker Clutch and it's a bit differnt than that brake design.
Old Sep 20, 2010 | 12:48 PM
Road_King_Rider
I put Whitbrake on my bike and have been riding with it for almost two weeks now. I saw the article about the brake in one of the Bagger mags and was very interested. I talked to Whit himself, asked a bunch of questions and was satisfied enough to buy one. The changeover is very simple. The whole process took about 30 minutes. I made the change because I have issues with the position of rear brake pedal and getting my foot stuck underneath the pedal.
The bracket holding the floorboard is very stout and fit into the floorboard with no problem. Once on the bike and in position the board now sits with a toe up/heel down position. It sits with toes up about ź” more than normal board position. This makes it easy to push down when braking. The board also sits out as far as it was before the change and I was using board extenders on my bike. If you boards are still in the stock position (i.e. close to the exhaust pipe) then you will notice the board now sitting father from the pipe.
Using the brake is straight forward, just push down on the front of the board and you’re braking. I know that some riders expressed concern about accidentally activating the rear brake. Based on my riding experience this would very hard to do. You have to physical push down in the front of the board to work the brake and it is noticeable physical action. I do ride around with my toes on my highway pegs and heels on the front of my floorboards so I was concerned about having my rear brake “on” without knowing it. But like I said you have push down to activate the brake and you WILL know that you’re pushing down. As far as standing on the floorboard while riding, I tried that out too and didn’t have problem, you have rotate you foot forward to activate the brake.
One thing I like about this brake setup is that it takes a lot of down pressure to lock-up the rear brake. In the past with standard petal setup it was/is very easy to lock up the rear wheel. Now I have to really push down to lock-up the rear brake which is something you don’t really want to do anyway. I’m saying it’s harder to as in it takes more pressure to lock-up the brake it is just a lot more noticeable physical action now when pushing down with you the front of you foot.
As with anything you change on your bike when it comes to rider setup there is going to be a learning curve. When using the brake the first few times it seems almost natural action to brake and because I was thinking about rear braking it didn’t seem like much. However, when it came to using the brake without thinking about it my first reaction was of course to lift my foot up and push on the brake pedal. Of course the pedal’s gone and for a brief nano-second it was an attention getting situation. A few more practice runs at emergency stopping got me in a happy place when it comes to braking. Bottom line, this is a nice change to rear braking. Is it better than current rear braking? That’s up to the rider. This rider likes change. I don’t have to worry about getting my boot stuck underneath the brake pedal and now it would be very hard to lock-up my rear wheel whereas in the past it was very easy to do. I can still get full rear braking without locking up the rear.
SGMongoose
2014-2024 Touring Models
15
Nov 27, 2015 06:55 AM
"Redwood"
Jun 3, 2012 06:49 PM
skim1420
Jul 6, 2009 06:20 PM
thumperhumper
Wheels/Tires
Apr 19, 2009 05:32 AM
harleyfanatic
May 23, 2007 02:34 AM
