Question
Old May 10, 2010 | 11:41 AM
randytro's Avatar
randytro
Default Question
Old May 10, 2010 | 11:54 AM
petemac's Avatar
petemac
You need to put something the width of a dime in there to keep from breaking that small brake light switch. That's what they're talking about.
Old May 10, 2010 | 12:13 PM
threeten's Avatar
threeten
Originally Posted by randytro
Are they talking about squeezing the brake lever and inserting something between the lever and the base of the lever so it can not close? then removing it from the handlebar.
Yes, exactly. Just use a thin piece of cardboard.
Old May 10, 2010 | 12:16 PM
Jags93's Avatar
Jags93
I used the head of a tie strap. probably opened it more than needed but still did the trick.
Old May 10, 2010 | 12:18 PM
gja's Avatar
gja
Pull on the brake lever, you will see a space between it and the housing. Place a shim of some sort (I used a zip tie folded, of course this was after breaking the switch the first time ) As others have said this is to prevent breaking the brake switch.
Old May 10, 2010 | 12:19 PM
TheBagger's Avatar
TheBagger
http://www.harley-davidson.com/en_US...ts/-J04165.pdf
Old May 10, 2010 | 12:21 PM
Harley_RN's Avatar
Harley_RN
Keep in mind that if you're only removing the brake lever you don't need to put that spacer in. You simply pull the lever in a little bit, and remove it. The only time you need to put a spacer in is when you are removing the master cylinder and the brake lever as one unit from the handlebars. You need to use a small flat bladed screwdriver to hold the brake light switch in a little bit when you are putting the lever back in. This is where it gets broken off.
Old May 10, 2010 | 02:30 PM
randytro's Avatar
randytro
BuckeyeRider
Nov 26, 2011 04:56 PM
fiveola
Shovelhead
Oct 12, 2010 02:44 PM
kevmic28
Oct 8, 2009 09:10 AM
jon0808
Mar 2, 2008 07:39 PM
shengte
Aug 5, 2007 03:44 PM
