What The Best Frame Stabilizer?
Old May 13, 2010 | 11:38 PM
1sweetglide08's Avatar
1sweetglide08
OK...I think I have it down to 2...The one from Throttle UP or the one from Progressive Suspension on eBay both are around $140-150.00. Im kinda leaning towards the one from Progessive Suspension I like how it's install. If anyone has either...what do you like or dislike about the products?
Old May 14, 2010 | 12:23 AM
BoomerBob's Avatar
BoomerBob
The only negative I can see with the Throttle Up system is if you later wanted to put a center stand on your bike. It doesn't look like it would work with one. You could always put a display stand at the bottom of your down tubes though.
Old May 14, 2010 | 03:20 AM
pit1600's Avatar
pit1600
Hello,
i've mount the Progressive Suspension system. It's the cheapest and work very well. Now it ride well even in solo with the TP on.
hope it help
Old Jun 2, 2010 | 08:09 PM
SOLOLUCKY's Avatar
SOLOLUCKY
So, I have an '08 Eglide...it has this wierd kick when going into a turn. really is kinda startling at times....can be anyway...is this potentially the "wobble" this thread is referring to?
The bike has 12k miles so I tend to not think a worn out part..
And if so, I am being led to believe that if i secure my trans to the frame (or am i securing the frame to the trans) that this wobble/kick will go away?
Can someone explain this phenomenom to me.
Old Jun 2, 2010 | 08:17 PM
sifularson's Avatar
sifularson
Originally Posted by 1sweetglide08
Thinking about buying a Stabilizer for my 08 StreetGlide. Need some help on which one...True Track, Bagger Brace or any others you guys know of. Which is the easiest to install and the best one for the money? Those of you that have installed a Stabilizer do you feel the difference and was it worth the money?
Take a look at this thread.
https://www.hdforums.com/forum/touri...nd-review.html
I've had the TWR stabilizer on my bike for 3 years. Works great, simple install, great part.
Old Jun 2, 2010 | 09:34 PM
SOLOLUCKY's Avatar
SOLOLUCKY
Well I guess it work...just trying to gigure out "how" it works...How the Trans being braced up helps/stops the wobble is all.
For 150 bucks I will end up with one...just would be curious as to how my money was being put to work.
Old Jun 2, 2010 | 09:38 PM
BoomerBob's Avatar
BoomerBob
Yeah. The stabilzer's secure the back of the trans to the frame at what can be considered the pivot point. The swingarm articulation point. It only secures it from lateral movement. Not up and down so the engine/trans can still rock back and forth on the rubber motor mounts.
Some people notice this movement in the back end and others don't. HD knew there was a problem when they went to better swingarm bushings in 2002. Then they corrected the problem altogether for the 2009 model year.
Most of the stablizer's work in the same way with the Progressive Touring Link being the least expensive. My buddy just got one for $122 on ebay. A few of the fixes work at the swingarm by replacing the bushings for a firmer polyurethane bushing. I haven't seen any evidence to tell me one is any better than another yet.
A good set of tires such as Dunlop E3's or Metzeler's coupled with one of the stabilizing devices will transform your ride to equal the 2009 and newer touring HD's.
Old Jun 2, 2010 | 09:57 PM
IceHeritage's Avatar
IceHeritage
Bagger Brace here
Old Jun 2, 2010 | 10:19 PM
BigDaddyOC's Avatar
BigDaddyOC
My wrench is very partial to the glide pro. After talking to him, reading all the articles on it etc I see some point to it, being that it doesn't add anything extra, no bolted on extras hanging off, limiting clearances or restricting any access. My problem...I've found very few that have used it to get feedback other than those posted to their site. On the other hand...many have used the True-trak and bagger brace and will vouch for it. Decisions decisions.....
Old Jun 3, 2010 | 09:58 AM
Beemervet's Avatar
Beemervet
THEY ALL WORK!
Stop thinking of it as wobble. It is a rear steer issue.
Find your price point and do it, there is no need to over-think this.
