front motor mount
Old May 16, 2010 | 06:22 PM
FOCI's Avatar
FOCI
Default front motor mount
is there anyone out there that had to replace frt. mount on their street glide is there any secrets or short cuts to doing it?
Old May 16, 2010 | 06:39 PM
dawg's Avatar
dawg
You can unbolt the motor mount and then use a floor jack to lift the engine enough to remove the mount. Removing the regulator and stabilizer link makes it easier to access.
Old May 16, 2010 | 07:04 PM
Apex Rider's Avatar
Apex Rider
This might help and give you an idea how easy it is....
http://www.moccsplace.com/images/mount/mount.htm
Old May 17, 2010 | 08:35 PM
bugs-06's Avatar
bugs-06
Check out Glide-Pro .com before you use that Harley junk.
Old May 17, 2010 | 08:36 PM
ANIMAL03's Avatar
ANIMAL03
++++ 100 on the glide-pro
Old May 17, 2010 | 10:23 PM
bagger05's Avatar
bagger05
++++1000 on the Glide-Pro mount, watch install video as bugs-06 suggests
Old May 17, 2010 | 10:31 PM
sifularson's Avatar
sifularson
I recently installed a Glide Pro front motor mount.
Did anyone else notice that it seems to be a softer rubber than stock?
Also note that you don't overtighten the center bolt. Torque wrench required!!!
Anyone?????????
Old May 18, 2010 | 05:06 AM
mainshaft's Avatar
mainshaft
Got my mount yesterday, plan on installing it after work today.
Old May 18, 2010 | 05:50 AM
bigtwin1228's Avatar
bigtwin1228
Put my Glide pro mount on Sunday do as bagger05 said go to web site and watch video. Easy job
Old May 28, 2010 | 02:50 PM
chaswood's Avatar
chaswood
Default Rear wheel alignment 08 touring fltr thanks
Hey guys just wanted to say thanks to the guys on one of the threads about bagger wobble...dont remember who ...doh.. I checked my back wheel with an 8ft aluminm straigt edge by jacking the bike up ( pit bull lift) and runnung it across the back wheel projecting it foward and discoverd that they where out 5/8 of an in... So i loosend the front motor mount and adj the top and bottom stabilizers (same amount of turns) and using a big screw driver to releave preasure on the bottom motor mount i lined it up.. Tightend the mounts and links. I used the manual for the basic concept and tourqe specs but the mo co way is to much bull crap and special tools that u dont need.. I little comon sence can go a long way.. Any way the bike cruses at 100mph like its in f---in rails compaird to the way it used too at 85 and whipin allover the place... Good luck charlie
mang0
Aug 3, 2016 11:26 AM
electra glide jim
Apr 14, 2010 03:48 PM
slack20
Mar 23, 2010 12:27 PM
1plumr1
Oct 12, 2009 03:49 PM
Brooklyn Redneck
Apr 3, 2007 12:14 PM
