Motor mount change-jack engine
Old Apr 14, 2010 | 02:07 PM
electra glide jim's Avatar
electra glide jim
Default Motor mount change-jack engine
What should be taken loose,so the engine can be jacked to change the mount?
Also does the flat side go up on the new type mount?
The bike is an 04 RK CUSTOM.
Thanks
Jim
Old Apr 14, 2010 | 03:48 PM
dawg's Avatar
dawg
You can unbolt the motor mount and then use a floor jack to lift the engine enough to remove the mount. Removing the regulator and stabilizer link makes it easier to access as well.
Ozark Joe
EVO
May 21, 2017 05:25 PM
crazytourglide
Jun 13, 2010 01:54 PM
FOCI
May 28, 2010 02:50 PM
07yellowglide
Apr 4, 2010 09:15 PM
1plumr1
Oct 12, 2009 03:49 PM
