Howling Primary
Old Jun 1, 2010 | 09:28 AM
vinnieee's Avatar
vinnieee
Originally Posted by Jonny Cannon
Giving it more thought, here's some more info:
1) It only does it when the engine is hot
2) It does not make the noise when the engine is in gear
3) It does not make the noise when the bike is driving
4) It does not make the noise when the clutch is pulled in
5) It only does it when the bike is put into neutral from gear, and only intermittently
Cannon
I just had my bike in for the 20,000 check up and they notice my Primary was leaking. They told me they had to order bearings to fix it - they said it was due to soft bearings. So my question is do you have any leaking from your primary? I searched the forum, but all I find in the primary bearing seal needs to be replaced not the bearings. Maybe they are trying to do both at once, since they are in there?
Old Jun 1, 2010 | 10:12 AM
vinnieee's Avatar
vinnieee
Does anyone have the part # for the bearings? Thanks!
I think I will fix this leaky primary myself after looking at the manual.
Old Jun 1, 2010 | 04:32 PM
vinnieee's Avatar
vinnieee
Or does anybody know the size of this bearing?
Old Jun 1, 2010 | 09:14 PM
Jonny Cannon's Avatar
Jonny Cannon
Nothing was leaking from my primary. The bearing & race on the inner were shot. I hope this is the last time I have to have the damned primary off. Two months ago I had everything off to replace my entire clutch assembly because my faulty starter wrecked my ring gear. Total repair costs to-date are almost 3 grand. Hooray.
Cannon
Old Jun 1, 2010 | 10:24 PM
sifularson's Avatar
sifularson
Look at this thread for the #s
https://www.hdforums.com/forum/prima...need-help.html
Old Jun 2, 2010 | 12:36 PM
vinnieee's Avatar
vinnieee
Cannon
Man 3 grand.
Old Jun 2, 2010 | 12:38 PM
vinnieee's Avatar
vinnieee
Originally Posted by sifularson
Thanks man. I'm going to give Baker.
Old Jun 2, 2010 | 12:59 PM
vinnieee's Avatar
vinnieee
The Baker High Torque Bearings fit HD 91-07, HD changed the size of the race in 08 so it looks like I'm going with HD part # 34091-08 plus gaskets.
Old Jun 2, 2010 | 01:06 PM
loydkc's Avatar
loydkc
2nd Gear
Same here, 07 FLHTCUI, inner primary bearing shot and race was coming out pushing on seal and starting to leak. If bearing comes apart it will take out other stuff with it.
Old Jun 3, 2010 | 08:56 PM
RangeRat's Avatar
RangeRat
I was on the road heading back from Rolling Thunder the other day when my trans mainshaft bearing crapped out too. An '07 RK with 30K miles and she started that scrapping sound on the way up. Was hoping to make it home but no go. Another Vet told me his '07 did the same thing too at about 30K.
