trans fluid low
Old May 23, 2010 | 08:37 PM
Tx_Rider's Avatar
Tx_Rider
Default trans fluid low
Changed my trans fluid about 1500 miles ago to Red Line V-twin SP. Used 1 Qrt. Checked my level today after a 30 min ride and it was right on the add line. Checked it on the jiffy stand as per the manual.
No leaks, would notice it "Bleeding" on the floor.
Not sure if it's worth it to get another bottle for a couple of oz just to bring it up a little. I'm positive the whole qt went in.
Old May 23, 2010 | 08:53 PM
dawg's Avatar
dawg
Per the owner manual or the service manual?
Old May 23, 2010 | 08:54 PM
smithbrl's Avatar
smithbrl
Is there anyway the transmission oil can leak into the engine or primary?
If not then don't use that oil anymore-it is evaporating LOL.
Personally, I'd keep a close eye on it and see if the level drops anymore.
Also I thought the transmission needs to be checked with the bike upright, I think that's how I do it but I can't remember because I never check it-just change it every 10k(might ought to start checking it). I looked in my service manual and it says check it on the kick stand.
Good Luck
PS Are you checking the level hot or cold? Service Manual doesn't specify. Don't know if it makes a difference, but it might.
Old May 23, 2010 | 09:04 PM
flhtupser's Avatar
flhtupser
Check on jiffy stand cold.
Old May 23, 2010 | 09:40 PM
Tx_Rider's Avatar
Tx_Rider
Service manual says jiffy stand after getting it to operating temp.
Old May 23, 2010 | 09:52 PM
dawg's Avatar
dawg
Also says to allow a short period of time to equalize lubricant level in the transmission compartments. I wouldn't worry about it. I'd keep an eye on it the next time you change it out.
Old May 23, 2010 | 09:54 PM
dawg's Avatar
dawg
Personally, FWIW, I change out my tranny fluid and generally never check it. I simply change it out at the next interval.
Old May 23, 2010 | 09:59 PM
RAP's Avatar
RAP
It tales 35 to 36 oz to bring it to the full mark.
Old May 23, 2010 | 10:00 PM
david christopher's Avatar
david christopher
me too
Old May 23, 2010 | 10:16 PM
Conehead's Avatar
Conehead
My service manual says: 32 ounces= 1 quart
