Are you thinking about an 07 Touring model?
Old Sep 13, 2006 | 02:59 PM
CT_Duke's Avatar
CT_Duke
Default RE: Are you thinking about an 07 Touring model?
ORIGINAL: eddybo69
Hell yea i am thinking about it....thinking they should hurry up and release my SE Ultra......I will put up with a little noise just to have a 110 with a 6. I put up with starter noise on my old cuda with a 440, and I loved that car. So I am not worried.
Good for you. By the way, the complaints are not about the starter. Let us know if you win the Harley Clatter Lottery when you buy the bike.
Old Sep 13, 2006 | 03:05 PM
CT_Duke's Avatar
CT_Duke
ORIGINAL: Biggzed
This from the MoCo tech tips to dealers:
TT258 – August 9, 2006
Primary Drive / Starter Noise Complaints
Several dealers and customers have commented about a “clunking” noise coming from the
primary housing during start up. Most dealers suspect a loose compensator because the
noise seems to come from the front of the housing. Customers tend to associate it with a
starter issue like improper starter drive engagement into the clutch’s ring gear. In fact the
condition they are noticing is what is referred to as “Starter Knock”. This is a normal sound
and condition for all 2007 Twin Cam models.
Changes in the primary drive system increased the diameter and inertial effects of the
rotating components (clutch and sprocket assembly, ring gear, and engine sprocket). Also,
the engine control system is calibrated to start the engine as quickly as possible (short crank
to run times) and to run up to the predetermined engine idle speed as quickly as possible to
provide very positive starting.
Because the engine fires and then runs up to speed very quickly, there is a large torque input
and instantaneous speed differential between the engine and spring loaded compensator
mounted between the engine and the driveline. The compensator is there to dampen the high
torque spikes inherent in a large displacement V-Twin.
Because of the increased inertia in the rotating components in the driveline, their rotational
speed cannot increase as fast as the engine, so the springs in the compensator momentarily
bottom and results in the sound that you hear.
The same sound exists in the 2006 Dyna models, but to a lesser extent. The increase in
displacement to 1584cc increased the torque spike and speed differential in the 2007’s and
causes the sound to be more noticeable.
There is no damage associated with the compensator bottoming.
Identifying characteristics of this condition:
1. It may be intermittent, as it is dependant on the start up conditions and how quickly the
ignition and engine RPM occurs.
2. It will be a single event. Once the starter is disengaged or the compensator is loaded
the sound will stop, unlike a loose sprocket assembly.
3. The condition may be more noticeable on Touring models due to the shorter primary
drive (shaft center to center distance) and associated shorter chain run. The extra
body parts like fairings and saddlebags also tend to reflect powertrain sounds upward,
towards your ears.
Wow, thanks. This answers all the questions about the clatter at all RPMs in 5th gear which has migrated to 6th gear on my bike!! As it turns out it is the starter. Gee I guess that means the a bunch of us riding about with the starter still engaged!! Thanks for this real enlightening response.
Does anyone out there READ? Did anyone read the word "starter" or "starting" in the original concerns? Whadda work for the MoCo and come up with answers to dance around the issue?
Old Sep 13, 2006 | 03:17 PM
schultz's Avatar
schultz
Yea yea yea. I have read it and read it. Would I buy a 07--hell yea. In fact my son beat me to it he ordered him one.
Old Sep 13, 2006 | 03:24 PM
DoCPooF's Avatar
DoCPooF
07 Here.....upset there are still no problems....Oh well...
Old Sep 13, 2006 | 03:32 PM
bountyhunter's Avatar
bountyhunter
Sure I'd buy an '07....but only if my '06 got wrecked or stolen! Certainly not contemplating trading up to an '07, simply for the new drivetrain. The only '07 that even perks my interest is the CVO Ultra.
Old Sep 13, 2006 | 03:39 PM
oldfartjc's Avatar
oldfartjc
ORIGINAL: bountyhunter
[sm=exactly.gif] what he said.
Old Sep 13, 2006 | 03:54 PM
DI75's Avatar
DI75
NOOOOOOOOOOO!!!!!!!!!!!!!!!!!!!!!!!
Old Sep 13, 2006 | 04:22 PM
drod's Avatar
drod
They need to call Porsche to come over and fix the problem with the '07's. Looks like they can't fix it them selfs. Buyer beware!
Old Sep 13, 2006 | 05:27 PM
FireHawk's Avatar
FireHawk
Nah, I'm happy with my 06.
Old Sep 13, 2006 | 05:36 PM
Akitakoi's Avatar
Akitakoi
Yes. Well no not thinking of, getting one.
Not worried about the noises, if mine has it, it will get fixed. There is only so many things it could be.
