88 TC Vibration
Old May 25, 2010 | 08:26 AM
BJFLHT's Avatar
BJFLHT
Default 88 TC Vibration
i came across a cherry 04 FLHT over the winter that was pure stock with no promblems. Since then i have added a set of older Screaming Eagle slip-ons, and recalibrated the carb. othere than that the motor is stock. My problem is now the bike vibrates the fairing bad at 1700-1800 rpms. Anything below is fine, and anything above that is fine. The bike runs extremly well without any issues at all other than this. What have i done to create this problem? Thanks
Old May 25, 2010 | 08:31 AM
cuda67bnl's Avatar
cuda67bnl
Inner faring brackets may be broken......
Old May 25, 2010 | 09:19 AM
rags's Avatar
rags
+1. That's the first place I would look.
Old May 25, 2010 | 09:37 AM
BJFLHT's Avatar
BJFLHT
So if i pull the outer fairing off will i be able to see the inner fairing brackets? Or are you referring to the chrome bracket on the outside of the inner fairing?
Old May 25, 2010 | 09:40 AM
cuda67bnl's Avatar
cuda67bnl
Yep, pull the outer fairing. Do a search on here. Been lots of posts about the brackets failing. There's a better bracket available now, if that's the problem.
Old May 25, 2010 | 10:10 AM
FastHoss's Avatar
FastHoss
I would check to be sure all your motor mounts are tight,the ones on the heads too.
Old May 25, 2010 | 11:18 AM
BJFLHT's Avatar
BJFLHT
I'll look into all these things tonight and see. Thanks
Old May 25, 2010 | 11:25 AM
Branded 1's Avatar
Branded 1
The silver brackets are not the actual fairing brackets they are just supports. The actual fairing mounting brackets will be painted black. Once the outer fairing is off you can't miss them.
Old May 26, 2010 | 08:33 AM
BJFLHT's Avatar
BJFLHT
Brackets appear to be fine and the motor mounts tight. Could this be a tuning issue? Maybe be a conicedence, be it started about right after the time i put the pipes on and redone the carb?
Old May 26, 2010 | 10:03 AM
mongomark's Avatar
mongomark
Pipes could be in a bind sending excessive vibrations through the frame. Check all the frame mounting points including at the rear of the pipe
