Need Help w/ Electrical Prob 2003 FLHRI
1. Rode over 200 miles in the country today. Everything fine.
2. Stopped for lunch and filled up with gas. Back on the road. Everything fine.
3. Few minutes later tried to honk horn, but no horn.
4. Came to road intersection, pulled in the clutch, engine died.
5. I was still rolling so I popped the clutch and restarted the engine. Noticed Speedometer not working (stuck on 47 mph), no odometer at all, turn signals not working, tail light on but no brake lights.
6. Engine kept running, tach was working. Headlight working. Came to another intersection, pulled in clutch and engine died again. Popped clutch and it restarted.
7. Engine would run as long as I kept the idle up around 1200 rpm. Did not want to risk it not starting so I headed for home.
8. Rode about 125 miles without letting the engine die. Headlight never got dimmer...stayed bright.
9. Once home, I shut it down. It did start again, but barely. Will not idle.
10. Speedometer still indicating 47 mph.
If anyone can offer suggestions, I would appreciate any input. Thank you!
Ronnie
Ronnie_K202@hotmail.com
PS: If I have posted this in the wrong forum, then I apologize. Please let me know which is the correct forum. Thanks
Ronnie
Also had a blown accessory fuze which explained the speedometer failure.
