Cam bearing failure...I think I'm going to be sick!
Old May 26, 2010 | 08:56 AM
will2002's Avatar
will2002
Clean it up, fix it up, and put another 100K on it! Not much else ya can do that would be half the fun.
Old May 26, 2010 | 09:12 AM
riteway's Avatar
riteway
Maybe rent or borrow a bike? The repair can always wait but the trip?....
Old May 26, 2010 | 09:32 AM
iclick's Avatar
iclick
Originally Posted by hog-doc
You will find a bunch of trash in the oil pan, DO NOT restart without pulling/cleaning the pan!
Just wondering about the crankcase. Isn't there likely to be bearing trash that fell toward the inside? Have you heard of many INA inner-cam bearings fail in TC's? I haven't, but his is an early-TC with the smaller 7/8" bearings.
Old May 26, 2010 | 10:18 AM
Beeracuda's Avatar
Beeracuda
The case has some minor damage to it. Tonight, I am going to install a bearing with Loctite stud & bearing mount and see how it feels going in. Hopefully, it will be OK...
I guess I will pull the pan and the drain plug in the case and try to flush any trash out of it.
Now, does anybody have any suggestions for camshafts? This is a 95" with HTCC heads and 10.5 to 1 compression....
rmc115's Avatar
rmc115
I have a friends 06 apart now with a failure, stock bike 23,000 miles. Everything is trash, debris everywhere. nothing is safe, lifters,bearings, pieces of roller broke the piston oilers off. what a mess. Mike
Old May 26, 2010 | 04:52 PM
jimski's Avatar
jimski
Originally Posted by boogaloodude
Sorry to hear that, hope you're back on the road soon.
All those guys thinking about a cam swap and keeping the stock INA bearings should look again at that picture.
I think that's good advice. I went ahead and ordered a pair last week. Both you and iclick have made a good point in other threads about this subject. Relatively inexpensive items that are well worth their cost just for the piece of mind they will provide.
Old May 26, 2010 | 08:12 PM
1sharprdkg's Avatar
1sharprdkg
That is a bummer for sure! But I did make a mental note about changing my cam bearings to the new style if I ever make a cam change... Thank You.
Old May 26, 2010 | 08:47 PM
davessworks's Avatar
davessworks
Originally Posted by Beeracuda
It's on my 02 RG. The cams were swapped before I got the bike. I've got almost 100K on the bike and the bearings probably have 70K. The rear bearing looks perfect. I found very little trash in the cam chest, but pieces have definitely been through the oil pump.
The oil pressure dropped about 10 lbs from normal on the way to work yesterday. That's why I decided to take a look.
I don't even want to think about pulling the pan again. That was such a pain in the butt last time. I will have to pull the swing arm to get it off. At least I have a table lift now...
Thanks for sharing - not good news but helpful for the rest of us. Good luck - I hope for the best.
Old May 26, 2010 | 09:12 PM
Beeracuda's Avatar
Beeracuda
Well, somewhat good news. I took the old rear bearing and installed it in the front. It went in and came out with the same force as in the rear position, so I think I'm going to be OK there. I'll still use a little Loctite on the bearing to be safe.
I went to the Harley shop this afternoon to price parts. I will be better off going to the SE billet cam plate and oil pump kit rather than buying the stock oil pump and cam tensioners. I haven't priced a Fueling pump yet, so I don't know what I will do just yet.
Old May 26, 2010 | 09:17 PM
Tucson_Tim's Avatar
Tucson_Tim
Sorry to hear this but 70K on cam bearings. Wow! That's pretty amazing I think. In a weird sort of way, I would be proud of that.
