Oil in air cleaner
Old May 26, 2010 | 04:24 PM
river rat's Avatar
river rat
Default Oil in air cleaner
Any good options to divert the oil back to the head or a breather filter to bridge between the two hoses? also I should mention bike has a stage 1 with a K&N filter
Old May 26, 2010 | 05:27 PM
nvsteve's Avatar
nvsteve
Easiest option is to run a half quart low. Won't hurt a thing.
Old May 26, 2010 | 06:10 PM
dgoodbmw's Avatar
dgoodbmw
Default breather
I just got some tubing and a plastic tee and removed the s hoses from the spigots to the air filter. I put the tubing on the ball ends in the head and ran tha tubing down to the bottom of the air filter housing and out behind the pushrod tube to the ground by the front of the engine.
Old May 26, 2010 | 06:21 PM
paguy's Avatar
paguy
Run less oil and use an oil that dosen't foam. I bet you have syn 3 in your motor.
Old May 26, 2010 | 06:25 PM
Sancho's Avatar
Sancho
I just read an article in an HD publication "Enthusiast Shoptalk" that says Draining the oil pan using normal procedures can leave as much a 1 quart of oil in the crankcase and cam chest area. This refers to 2007 to 2010 touring models.
Last time I changed oil I added 3.5 qts like the book says and I was overfilled. I had to suck about 1/2 qt out. So if you add 3.5 qts like the book says you could be overfilling by 1/2 qt. This will result in blowing oil out of your cleaner and oil not draining from the cam chest area. The oil that will not drain from the cam chest area will not show on the dipstick.
Old May 27, 2010 | 03:56 PM
river rat's Avatar
river rat
No Syn 3. Amsoil, dipstick showing 3/4 full. I'll just live with it til next oil change
Old May 27, 2010 | 08:36 PM
heywood727's Avatar
heywood727
Doherty Power Pacc with power vents
apblingAEW
Aug 29, 2015 06:25 PM
woosh
Jun 30, 2011 10:45 PM
azdyna
Dec 17, 2009 06:43 PM
DPete
Aug 8, 2009 07:04 AM
Russell
Exhaust System Topics
Sep 19, 2005 09:06 PM
