Need some Help!!
Old May 27, 2010 | 12:24 PM
Bikergirlie's Avatar
Bikergirlie
Stage II
Default Need some Help!!
I have an 07 Streetglide...took it to a local shop to have the 11" stock air shocks changed to 13" progressives...also had a 1 1/2" lowering kit installed cause I like the lowered look...on the ride home heard a rubbing sound when riding over rough areas in the road...took it back in to find that the bolt on the lowering kit was rubbing the inside of my bag....any ideas on how to fix?? Or will I not be able to have the lowering kit on...thankx ; )
Old May 27, 2010 | 12:26 PM
Hunter2678's Avatar
Hunter2678
so you removed the shorter factory suspension and replaced it with longer travel suspension but re-lowered it again?..
Old May 27, 2010 | 12:32 PM
Bikergirlie
Stage II
Yes...I wanted the lowered look with a better ride...it used to hit pretty hard w the 11's on
Old May 27, 2010 | 12:37 PM
oldbiker771's Avatar
oldbiker771
Shorter bolt. Or turn it around. Or saw off the protuding threads.
luckyOne
Mar 29, 2015 10:03 AM
cbky71
Jan 4, 2012 09:08 AM
dunnboyfl
Oct 21, 2010 08:26 PM
bulldogmoe7
Jul 20, 2008 11:30 AM
dwike
Jan 16, 2007 07:36 PM
