Rust in the tank
Old Jun 5, 2010 | 07:25 AM
jhughes484's Avatar
jhughes484
Default Rust in the tank
Im working on a bike that has been sitting in storage for 25 years. Fuel tank is full of rust. Is there a good way that I can clean it? Any products on the market that will clean it?
Thanks for the Help.
Old Jun 5, 2010 | 07:40 AM
Route66rider's Avatar
Route66rider
A lot will depend on how the tank is designed. Safe to say if it has sat for 25 years it won't have FI. As to cleaning it, I rebuilt an old MG Midget and it had a similar issue. Get a handful of galvenized 3/8 nuts & lockwashers from the chainlink fence area in Lowes or Home Depot. Drop them in the tank & shake, rinse and repeat. You will be amazed at what comes out. Keep at it until it rinses out clear. The old car had a 8.5 gallon tank & I finished it out in about an hour. I ran several thousand miles before I sold it.
Old Jun 5, 2010 | 08:32 AM
katobird's Avatar
katobird
Marbles, Small rocks, Ceramic Pieces, etc
Just keep them small enough not to dent the tank..
Or put them on the Air compresser or something that vibrates for a while
Yup put them in the tank and you'll see what comes out
Old Jun 5, 2010 | 08:39 AM
47Norton's Avatar
47Norton
You could also try a handful of drywall screws. Works good for removing crud. Lots of sharp little points.
Old Jun 5, 2010 | 08:42 AM
n8dc's Avatar
n8dc
acetone works also after the nut and bolt trick but the acetone will clean it good enuff that it will want to rust up right away. Id use the nut and bolt trick then a good wash with hot soapy water then acetone then dry it good and apply a sealer to the inside then it should be good to go.
Old Jun 5, 2010 | 09:25 AM
wink2206's Avatar
wink2206
Default cycle tank repair kit
You could try this: http://www.por15.com/CYCLE-TANK-REPA...ductinfo/CTRK/
Haven't used this kit, but used other products from them. Very good products. This would be the way to go if you cannot replace the tank.
Old Jun 5, 2010 | 09:40 AM
Dionicio's Avatar
Dionicio
Take it to a good radiator shop. have them soak in caustic to get any varnish out of it. Then use a good rust remover (naval Jelly) to get the rust out, and use a good quality gas take sealer. I've had excellant results doing this with old tanks.
Old Jun 5, 2010 | 10:51 PM
ucommbxny's Avatar
ucommbxny
i did a tank in the late 70's used radiator rust remover flush, then coated inside of tank with a product called kreme
ClodeV
Aug 28, 2014 02:18 PM
DENGUY
Feb 14, 2010 10:58 PM
claaster
Exhaust System Topics
Jun 26, 2009 08:10 PM
Keith_71
Feb 27, 2009 07:01 PM
bartles
May 15, 2008 12:31 PM
