Changed to shorty antenna
Old Jun 10, 2010 | 08:06 PM
masterblaster's Avatar
masterblaster
Default Changed to shorty antenna
Like the look but no reception at all now.
Old Jun 10, 2010 | 08:10 PM
Indiana Bob's Avatar
Indiana Bob
Which antenna did you use?
t. sawyer's Avatar
t. sawyer
Must depend on the area. Course I like to just listen to the out side sounds. Just me.
Old Jun 10, 2010 | 08:14 PM
masterblaster
the 19 inch, the right pn for 09 later on the cb and the 78 later for the radio.
Old Jun 10, 2010 | 08:16 PM
Indiana Bob
I was just about to do the same but I may hold off now. I don't like the "look" of the long whip but I like the "work"!
timbo141's Avatar
timbo141
Time for XM
Old Jun 10, 2010 | 08:19 PM
2WheelGlider's Avatar
2WheelGlider
I have changed both and have found very little difference between the 2 as far as reception goes. Had the largest impact on CB, really no difference on FM
Old Jun 10, 2010 | 08:21 PM
masterblaster
There is no reception, not reduced reception, absolutely no reception. I have XM and it works but the AM/FM is not working.
Old Jun 10, 2010 | 09:49 PM
BBStacker's Avatar
BBStacker
Changed to the shorty about 6 months back no change in reception on any band. Have you tried putting the whip back on again? Check for evidence of corrosion, broken antenna wire?
Replacing just the antenna should not have caused the all bands not to function. JMHO.
Old Jun 10, 2010 | 09:54 PM
tedcmiller (Cry Baby)'s Avatar
You replaced the AM/FM antenna. The XM antenna is a different antenna. Replacing the AM/FM antenna would have no effect on XM reception.
As indicated by a previous post, a shorter CB antenna is not going to work as well as a longer CB antenna. This, of course, assumes that the short CB antenna is SWR matched to the transmitter. A short CB antenna that is not SWR matched could destroy the CB transmitter. It would have no damaging effect on the CB receiver, but would not receive as well. In any case, longer (for both AM/FM and CB) is always better, and this applies to antennas as well as other things.
