Floating Rotors
Old Aug 22, 2006 | 09:58 PM
Abnmarine's Avatar
Abnmarine
Default RE: Floating Rotors
Same here except that I use Lyndall pads for front & rear. Superb braking with little to no dust.
ORIGINAL: 98kingflh
Yup, I'm with bountyhunter. 88$ each from Zanoti's...Very easy swap..
Old Aug 23, 2006 | 12:08 AM
Panhead_1_9_4_8's Avatar
Panhead_1_9_4_8
An cooler (less heat) breaking system.
Old Aug 23, 2006 | 12:21 AM
Topper's Avatar
Topper
ORIGINAL: hduc2005
hey Bountyhunter Did you replace your brake pads at the same time?
Yes, change the pads, lose the OEM pads and try some Lyndall's, great pads!
Old Aug 23, 2006 | 10:57 AM
timbo's Avatar
timbo
Topper, that is one bad *** lookin' Street Glide! Love the Thunderheader and wheels. Where did you get the wheels and rotors?
Old Aug 23, 2006 | 11:44 AM
solorider's Avatar
solorider
ORIGINAL: bountyhunter
Better performance, longer pad life, no squealing, quality stainless/less corrosion and COOLER appearance.
Perfect, that's what I wanted to know. Thanks!
Old Aug 23, 2006 | 02:06 PM
Big O Dave's Avatar
Big O Dave
Mine came from the dealer with front HD floaters. Slight squeaking at low speeds with no brake application, but goes away when applied. Makes noticeable "rubbing" sound, probably all the time, but only discernable at low speeds. Neither noise bothers me.
Topper, that bike is one of the most beautiful I've ever seen! Great job!!![sm=Awwww.gif]
Old Aug 23, 2006 | 02:26 PM
mchacon's Avatar
mchacon
Topper, Your rotors appear to be smaller in diameter than some of the others. Are you using stock calipers?
Old Aug 23, 2006 | 07:40 PM
Topper's Avatar
Topper
Timbo, Thanks! Wheels and rotors are made by Perfomance Machine www.performancemachine.com
Big O Dave, Thanks!
mchacon, yes, I'm still running stock calipers for now. Rotors are 13".
Old Aug 24, 2006 | 12:43 PM
eglidebob's Avatar
eglidebob
Is that Zanotti in Butler, PA? Thanks
mattk22
Aug 18, 2011 06:58 AM
08roadglidejoe
Wheels/Tires
Jul 20, 2010 11:02 AM
chromedome
Jun 12, 2008 11:09 PM
MNPGRider
Oct 24, 2007 04:51 AM
woodreaux
Aug 22, 2007 11:15 AM
