Greasing steering head bearings
Old Jun 19, 2010 | 11:14 PM
RK4ME's Avatar
RK4ME
Originally Posted by KingCripps
Just say no, don't do it. They are not "spinning" bearings and don't need to be greased often, if ever. I had the dealership do one of the services on my Deuce and I was cleaning grease off the tank and off my pants for the rest of the Summer. They are not at all likely to freeze up.
It's not about freezing up. It's about keeping a lubrication barrier between the rolling elements and races of the steering head bearings in order to prevent brinelling. If left unchecked on some bikes, especially those with frame flex, steering head bearing brinelling will cause the bearings to go out of adjustment, resulting in high speed ocillation/wobble and loss of
control. That's been MY experience.
Old Mar 11, 2011 | 02:42 PM
Jerzmatic's Avatar
Jerzmatic
OMG !!! This is happening to me !!! I have a 2000 Ultra and when I reach speeds of 90+ the bike goes into this massive wobble. I have done everything to the bike from change out the main and side fairing brackets, added an after market rear stabilizer but all the while the issue has been in the front I can feel it.
The dealer suggested it might be my neck bearings and that it would run 700 bucks to change them out. I'm desperate at this point to resolve this issue whatever it is. I feel like the cost is nothing short of rape but, i'd love to ride this bike for once since i've owned it without this happening !!!
Suggestions?
Old Mar 11, 2011 | 10:22 PM
Harleyboyddk's Avatar
Harleyboyddk
Check rocknrod's post. Use the Thexton 418 right angle grease coupler. Made in USA. Also available from Snapon.com , free shipping as well. What my HD dealer uses.
Old Mar 11, 2011 | 10:46 PM
sniperduce's Avatar
sniperduce
Autozone 8 bucks for a 90 degree grease gun adapter, I give it 4 pumps each oil change & then ride.....
Old Mar 12, 2011 | 05:57 AM
fabrik8r's Avatar
fabrik8r
I replaced the staight zerk with a 90 degree, I used thread tape and trial and error to get it positioned for easy access with the grease gun. I also applied conventional wisdom when adding grease, and kept on pumping unti I saw it pushing out the top or bottom of the neck; BAD IDEA. In the end I think I added about 30 pumps of grease, and I've had grease blowing all over the bike ever since; real nice. Give it a few pumps and forget about it for 20-30k miles.
Old Mar 12, 2011 | 06:50 AM
1flhtk4me's Avatar
1flhtk4me
Better to do it that way, just wipe off the excess grease IMO.
Old Mar 12, 2011 | 08:17 AM
Ronp42's Avatar
Ronp42
Account Retired
I did mine and my wifes 2010 SG Trike. Pumped both until grease ran out top and bottom. No problem with grease running out this past summer. I used Amsoil Synthetic High Temp grease. Read farther back in this Thread and you'll see where others like iclick used Royal Purple. It's the type of grease that makes the difference. IMO
Old Mar 12, 2011 | 10:18 AM
larsfum's Avatar
larsfum
Used the blue marine grade grease. More water resistant, and have not had a problem with it dripping out. Before I greased the steering bearings the bike was clunking over moderate bumps. No more clunk.
Old Mar 12, 2011 | 10:19 AM
ftanner's Avatar
ftanner
Originally Posted by robbie52
the best way is to change out the grease fitting and be sure to use a grease compatible with the recommended grease or buy the Harley grease.
I, personally, use Mobil 1 synthetic bearing grease. Works just fine. In addition, it doesn't drip as much.
Old Mar 12, 2011 | 06:25 PM
iclick's Avatar
iclick
According to the service manual you're supposed to fill the head with grease at the 1000-mile service, then inject more for every 5000-mile service until it oozes from the top or bottom of the head. The grease overflow you're getting is the grease liquifying and running down the left fork. Some grease will not run, and I've had no trouble with Royal Purple NLGI #2 grease. As an added measure I also cut a section of foam-rubber and inserted it in the left-section of the tray adjacent to the steering head. It soaks up whatever run-off I get from the remnants of the original grease.
