Eitms kicks in at what oil temp???
Old Jun 24, 2010 | 04:18 PM
Arizona's Avatar
Arizona
Originally Posted by FLHTCU Owner
This is from the Super Tuner Users manual:
Phase I: If the ECM detects engine temperature above approximately 300° F while moving or
stationary it reduces the idle speed. A lower idle speed produces fewer combustion events per minute
and that reduces engine heat.
Phase II: If the ECM detects an engine temperature that’s still drifting higher while moving or
stationary it richens the AFR. An increased amount of fuel in the air/fuel mixture has a cooling effect
on the engine.
Phase III: If the ECM detects an engine temperature that’s still drifting higher while moving or
stationary it directs the fuel injectors to skip, (only when the bike is stationary) and not deliver fuel on
every intake stroke. This limits the number of combustion events taking place, which produces less
heat.
The three phases just described function seamlessly, and the rider may not notice the transition from
one phase to the next.
Interesting. This is the first time I've seen this. Does this occur on all model years? I didn't know there are things that happen even while the bike is moving to reduce heat. I thought i was just when the bike is at idle in high heat conditions...
Old Jun 24, 2010 | 04:46 PM
lp's Avatar
lp
No mention of the rear cylinder shutdown in any of those phases.
This may have been superseded...
lp
Old Jun 24, 2010 | 05:18 PM
rushbass's Avatar
rushbass
Originally Posted by Jags93
I never heard this before. You would think phase III would be noticeable?
You bet it's noticable (running on one cylinder)... I thought I was having engine trouble the first time the EITMS kicked in... LOL!
I then preceded to turn the EITMS off once I got to where I was going...
Old Jun 24, 2010 | 06:31 PM
Gaspumpcity's Avatar
Gaspumpcity
Happened to me on the dyno from what the dyno guy said he sees more 09-10 T/C doing it. Started cutting out when oil temp got to 260 deg also it had 3 high powered fans too.I asked where the sensor was at said it reads from the head temp.
Old Jun 24, 2010 | 07:07 PM
mailmanhugh's Avatar
mailmanhugh
So, what about shutting off the bike when sitting at a long red light? Is that preferable to letting the EITMS shut down the rear cylinder fuel and just idling like that? This is my first Harley and first air cooled bike and I just want to make sure I don't fry my motor sitting in traffic idling on one cylinder.
Old Jun 24, 2010 | 07:43 PM
Gordon65's Avatar
Gordon65
EITMS is an additional mode, beyond the three stages listed earlier in this thread.
EITMS kicks in at about 300 degrees, and vehicle not moving, and at idle.
Old Jun 24, 2010 | 07:48 PM
BoomerBob's Avatar
BoomerBob
Just so the OP knows ... it goes by "head temp" not oil temp.
Old Jun 24, 2010 | 11:28 PM
iclick's Avatar
iclick
Oil temperature and head temperature are not directly related, and you can't use a formula (like CHT-30°=OT) to calculate one or the other based on one known value. The oil temp will follow the head temp, but it lags far behind it, both increasing and decreasing. You can see this readily by monitoring both together as I've been doing for the past two months. I've seen CHT, measured from the bike's J1850 port (FCHT sensor), hit 280° in summer traffic while OT was <200°. CHT will change before your eyes based mostly on the amount and temperature of the air flowing over the cylinders, but OT changes with the speed of molasses.
EITMS is regulated by the front CHT, and when it kicks in varies from year to year. My '07 kicked in at exactly 290°, but I've heard later models do so earlier, like 285°. I used past-tense because I just updated the ECM which nixed EITMS on my '07, but it almost never kicked in on the road anyway.
Old Jun 25, 2010 | 11:22 AM
flipbel's Avatar
flipbel
Thanks for all your relies. I did ask for a correlation but I guess I asked the wrong question. For those that have oil gauges, at what temperature does the eitms normally kick in? I know I got about 250* but just curious. Once again thanks for your input.
Old Jun 25, 2010 | 12:03 PM
iclick's Avatar
iclick
I think I answered your question in my reply above, or tried to. You may see some correlation between OT and EITMS kicking in if you're consistent in your riding. For example, crank the bike cold and let it idle until EITMS enables. When this happens I'll wager your oil temp is not particularly hot yet since CHT will increase quickly when stationary and it takes a while for OT to catch up. After that take a normal ride that will usually cause EITMS to enable, and I'll bet you'll see a much hotter OT than the first example.
If you really want to keep tabs on when EITMS kicks in you should get a CHT gauge.
