Exhaust install question
Old Jun 25, 2010 | 07:26 AM
Winston's Avatar
Winston
Default Exhaust install question
Hi guys,
i have a 2010 ultra and want to change the exhaust to vance and hines big shot duals. Can i just change the exhaust or do i have to add the power commander and upgrade the air intake?
Thanks for any info..................Limey
Old Jun 25, 2010 | 08:17 AM
wingfoot's Avatar
wingfoot
No fuel adder needed for the slip-on mufflers. You may want to look into removing the CAT in the head pipe!!
You can remove the CAT in a few different ways; one is to dissect your stock head pipe and remove the CAT material or buy one of the three or four head pipes made for the 2010 with no CAT(s).
Only if you add more air to the mix will you need to get the fuel adder.
Note: even though you would not NEED the fuel adder without the added air intake, it would help reduce the lean condition that is engineered from the MOCO.
Old Jun 25, 2010 | 01:37 PM
Winston's Avatar
Winston
hi rick,
the big duals is a complete exhaust. so i assume the factory head pipes will come off also.
thx...limey
Old Jun 25, 2010 | 03:23 PM
wingfoot's Avatar
wingfoot
Originally Posted by limey73
hi rick,
thx...limey
CRAP, I seel ftupid.
Old Jun 25, 2010 | 03:46 PM
SG 1's Avatar
SG 1
Steel Fupid
How you feel now...J/K
Old Jun 25, 2010 | 03:50 PM
wingfoot's Avatar
wingfoot
Originally Posted by SG 1
Steel Fupid
That sounds better even if it is not right!!
workingdan
Sep 27, 2012 05:10 PM
streetglide_medic
May 29, 2011 01:03 PM
HDPIG403
Jul 29, 2010 08:31 PM
spider2
Jul 20, 2010 05:42 PM
bigdog8727
Nov 20, 2007 09:02 PM
