Broken swing arm
Old Jun 27, 2010 | 04:40 PM
Pyatt5's Avatar
Pyatt5
It did have one on it. I think that was a mistake on my part. I have the harley lowered shocks but I have removed that 1 inch lowering add on bracket. I'm sure that that contributed to the failure. I have many friends who have used that lowering bracket and have had no concerns and I will be sure to show them the picture of my broken swing arm.
Old Jun 27, 2010 | 04:47 PM
Pyatt5's Avatar
Pyatt5
Yes I did have that add on bracket that lowers one inch. A lot of my friends have them and have had no concerns. I am going to be showing them the picture of my failure and they will probably be taking theirs off. I have removed it and it will not be going back on. I have the harley lowering shocks and will just stick with those for now.
Old Jun 27, 2010 | 05:13 PM
NMNSG08's Avatar
NMNSG08
That looks to me like it was definetly the mechanics fault.
Old Jun 27, 2010 | 05:30 PM
Egldr05's Avatar
Egldr05
Let me know if you're interested in a used one. I'm getting ready to list on EBay.
Rick
Old Jun 27, 2010 | 10:40 PM
Paniolo's Avatar
Paniolo
That lowering kit is a big contributing factor. What it does is move the shock bottom back 1 inch further. That moves the load back further and adds more stress on the axle and hole. It exacerbates the teeter-totter issue.
Old Jun 28, 2010 | 03:52 AM
grbrown's Avatar
grbrown
I don't believe that is the case. As others have written, this is not uncommon.
I have recently fitted a 2007 swingarm in my Evo and wrote about it in my thread Suspension THUMP, where you can learn all about doing it!
I didn't have the cracking problem and was looking to cure bottoming out, but replaced the rear end as part of my project. I've done over 3k miles on it since with complete success.
Old Jun 28, 2010 | 06:32 AM
pgpn's Avatar
pgpn
mine broke completely out. broke pulley,rubbed belt/tire. turned it in to ins. they denied the swing arm itself but paid for all the resulting damage. goin back stock.
Old Jun 28, 2010 | 07:38 AM
imrotton2's Avatar
imrotton2
i had mine break also... over torque,(maybe) but i think its just a bad design.. theres too much slop on the internal axel adjusters(a better adjuster is offered)and the wheel bushing on the pulley side really needed to be larger in diameter where it touches the swing arm... i dont think the lowering blocks is the problem(breaks on the pulley side ---not the brake side)
Old Jun 28, 2010 | 08:49 AM
grbrown's Avatar
grbrown
The only few I know of have all had lowering blocks. It is such a sloppy design. There is a sandwich of several things being squashed together by the axle. The later swingarm is much better with its solid ends.
Old Jun 28, 2010 | 10:54 AM
buick455gs's Avatar
buick455gs
Thanks for the post I will check my 2001. Looks like HD did not do a simple stress analysis on this part.
