Activate Auto Comp release
Old Jul 1, 2010 | 06:43 PM
SE120RG's Avatar
SE120RG
Default Activate Auto Comp release
If I install a set of SE heads that already have the ACR installed I know I have to purchase the wiring harness but I also remember reading somewhere that you have to activate the ACR by getting into the ECM and reprograming something. Is this correct and is this something an Indy can do or only HD tech?
Old Jul 1, 2010 | 08:56 PM
tedcmiller (Cry Baby)'s Avatar
All 96 cu. in. and larger engines from H-D have automatic compression release (that is why it sounds like a gun shot when they start up). If you have a 96 cu. in. or larger motor (a 2007 model should), activation of the ACR should already exist.
Old Jul 1, 2010 | 10:25 PM
RK14SGS's Avatar
RK14SGS
You need to purchase the harnesses, and then activate ACR through the ECM program. It can be done with the SE ProRacetuner; otherwise the dealer has to do it. Or if an indy has the HD service software/pc system (Digitech i think is the name?), then they should be able to activate ACR iva the ECM.
yamaracer18
Exhaust System Topics
Jan 19, 2012 12:30 PM
Craig C.
Nov 1, 2011 07:31 PM
Just Enough
Dec 27, 2010 09:25 AM
Rink-A-Dink
Aug 16, 2010 03:38 PM
bcasinger
Aug 31, 2007 04:35 PM
