Engine Issue 2003 FLHRCI
Old Jul 4, 2010 | 12:41 PM
moose1950's Avatar
moose1950
Stage I
Default Engine Issue 2003 FLHRCI
This one has me boggled. My 2003 is equipped with a TC 88 A. It has stage one, a V&H Fuel Pack, Screaminf Eagle Air Intake, V&H true duals and slip-ons. No other modifications have been made since approximately 15,000 of its current 46,000 miles.
On a very hot day, I recently notice d my speedo acting eratically and then falling to zero, my signal indicators would not shut off automatically and I could not hold an idle. This happened after approx. 80 miles of riding.
From then on, it has become a constant event, as described and only happens when running hot. Starts off fine then 60 to 80 miles down the road, idle is lost. This far I have replaced the sensor for low end idle (next to the oil filter). An intake air leak has been suggested, but doesn't sound right if it takes 60 miles or so to expose the issue. My guess is ECD that somehow gets goofy after that amount of time on the engine.
Looking for help. BTW, I am not throwing any codes, although the engine light has come on a few times, only to shut itself off. I have also run without the fuel pack, same issues.
Help!
Old Jul 4, 2010 | 12:54 PM
dcfatboy's Avatar
dcfatboy
Does your bike have the maxi-fuse or the circuit breaker?
Old Jul 5, 2010 | 06:48 AM
Egldr05's Avatar
Egldr05
Check the grounds inside the fairing. It turned out to be my problem.
Rick
Old Jul 5, 2010 | 07:01 AM
chasswartz's Avatar
chasswartz
Check battery conections, battery, and grounds in the fairing as sugested above, and main ground. Sounds like a battery or connection issue.
Old Jul 5, 2010 | 08:12 AM
CroK's Avatar
CroK
Might also be a good idea to pull the speed sensor and clean the tip. A dirty speed sensor can cause the probs you describe with your speedometer...
Old Jul 5, 2010 | 11:55 AM
DTTJGlide's Avatar
DTTJGlide
As CroK said the speed sensor is the source of your speedo & turn signal problem, the auto cancel on the signals is speed sensitive, thus if speedo reads zero it thinks you're sitting still. I don't know if that has any connection with your idle problem. Sometimes you can get by with just cleaning the speed sensor, but it will need to be replaced eventually.
Old Jul 5, 2010 | 03:35 PM
Egldr05's Avatar
Egldr05
Dealer thought it was the speed sensor causing the issues with my speedo but it wasn't. I had the same symptoms as the OP and after 2 sensors and a speedo it still wasn't fixed. I found the ground problem while removing the inner fairing for paint. I removed the grounds, scraped the powder coat off to bare metal put a coat of copper shield on and reinstalled the grounds. I haven't had a problem since (2 years). It may be your sensor but it very well could be something else such as a broken wire or bad ground and yes the speedo issue will affect your idle, at least it did on mine.
Rick
mikeo33y
Jul 5, 2018 07:45 PM
DanTheBetterMan
Aug 25, 2015 04:00 PM
hoogahooga
Apr 4, 2012 11:41 AM
tarheelrdr
Nov 1, 2010 10:06 AM
PLHOG
Apr 23, 2005 07:05 PM
