Idle problems
Old Jul 4, 2010 | 01:29 PM
Bodean46's Avatar
Bodean46
Default Idle problems
Took off for a trip to central Michigan on Monday. Bike ran fine and idled like it usually does. On Thursday night fueled up at a shell and rode to Holland where it ran fine til i shut it off. Since, it wants to die at idle and has a hesitation when taking off. I've added Seafoam to the gass and it seemed to help for a bit then went right back to hesitating and not wanting to idle. 7 hour trip home at 70 to 80 mph and still no better even adding new gas. Could this be caused by bad gas or maybe the fuel fiter needs changed. You can see by my sig it's an 01 Ultra with 27000 miles and the MM injection system. Any ideas?
Old Jul 5, 2010 | 06:36 AM
Bodean46's Avatar
Bodean46
Bump, any ideas?
Old Jul 5, 2010 | 06:53 AM
cuda67bnl's Avatar
cuda67bnl
Is it idling low now, or just missing at idle?
Grab a spray can of throttle body cleaner. Pull the air filter and give it a good cleaning.
Old Jul 5, 2010 | 07:55 AM
Bodean46's Avatar
Bodean46
Thanks, that's this mornings project. Sprayed carb cleaner around intake and no leaks. Just started doing it after sitting in a parking lot for a couple of hours. I'm going to shoot some Seafoam down the intake and clean air filter and see what happens.
Old Jul 5, 2010 | 08:08 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Clean the Idle air control valve.
Drew
Old Jul 5, 2010 | 08:12 AM
imrotton2's Avatar
imrotton2
i hafta do the adjustments on the mm injection about ever 2 or 3 years.. do the adjustments with the service manual and its not hard to do
Old Jul 5, 2010 | 01:14 PM
larsfum's Avatar
larsfum
I would start with simple solutions first. As stated before, clean the throttle body, and the IAC valve.
You also might want to Sync the ECM by disconnecting the battery for about 30 min. Then Reconnect the battery. Turn handlebar run switch to ON. Turn key ON for 5 sec., then OFF. Repeat ON/ OFF sequence a second time. Sometimes the ECM forgets what it should do.
Old Jul 5, 2010 | 01:23 PM
dansflhti's Avatar
dansflhti
The engine temp sensor went bad on my 06 with similar symptoms.
Old Jul 5, 2010 | 02:51 PM
Bodean46's Avatar
Bodean46
Cleaned intake and AIC with SeaFoam sprayed in the intake while running and then shut it off and sprayed AIC with it. It will try to idle for a few seconds then drop down to 750 rpm's then eventually die. Starts right back up and goes down road fine, so i'll take it my indie and have hime check Temp sensors as that is a good possibility since they are all original. Thanks everyone for you input, It really does help.
Old Jul 5, 2010 | 02:54 PM
cuda67bnl's Avatar
cuda67bnl
Almost sounds like it lost it's idle memory. They're known to do that once in a while.
