Idle problems
Old Jul 5, 2010 | 03:12 PM
Bodean46's Avatar
Bodean46
i haven't tried the battery disconnect yet so maybe back to the garage and give that a try. Thanks again.
Old Jul 5, 2010 | 03:54 PM
Bodean46's Avatar
Bodean46
I have a PCIII installed and had it dyno'd. Will doing the battery disconnect cause any problems with this?
Old Jul 5, 2010 | 04:32 PM
cuda67bnl's Avatar
cuda67bnl
Nope, no problems.
Old Jul 6, 2010 | 05:32 AM
Bodean46's Avatar
Bodean46
Did the battery disconnect, no change. Pulled ECM fuse, no change. Flashing codes faster than i can count, but think it's showing TPS code as well as Temp sensor code so i'll get it to my indie and let him figure it out.
Old Jul 16, 2010 | 01:17 PM
Bodean46's Avatar
Bodean46
Indy found bad fuel regulator, bad return line, and fuel pump. Regulator sucked pieces of o-ring into it and stuck open which allowed pressure up to 75lbs, with stock being 45lbs, and caused pump to burn up and maintain that pressure in return which caused my idleing problem.
FXD_noob
Nov 18, 2015 10:07 AM
slim12
Sep 10, 2013 08:58 AM
Mcatee2006dyna
Aug 10, 2011 09:04 PM
hawc929
Welcome Area Only
Apr 26, 2011 05:54 PM
valkal
Exhaust System Topics
Aug 18, 2008 09:34 AM
