Fairing Stereo Options
Old Jul 9, 2010 | 08:13 PM
meanjean's Avatar
meanjean
Default Fairing Stereo Options
What are options to mount a standard 12volt car stereo in a batwing fairing?
Is there a mounting kit designed to accomodate that style radio? I know the opening "as is" is too large.
My fairing I purchased used has no stereo and want to add a marine style stereo.
Thanks
Old Jul 9, 2010 | 09:14 PM
BillyG0856's Avatar
BillyG0856
Try Biketronics.
They should have any and everything you'd want.
Old Jul 10, 2010 | 07:15 AM
pit1600's Avatar
pit1600
Thanks
Try Hawgwired. I think more clean than biketronics and istallation is very easy
I have a Sony wich sound well, more better than OEM ons
Old Jul 10, 2010 | 07:52 AM
troop's Avatar
troop
I have a Kenwood deck in my bike. I'm thinking basic DIN type receivers will fit with a face plate.
Old Jul 10, 2010 | 07:54 AM
2WheelGlider's Avatar
2WheelGlider
IMO the hawgwired set up is definately a cleaner install than most of the other ones I have seen.
Old Jul 10, 2010 | 11:44 AM
Harleypingman's Avatar
Harleypingman
Meanjean, are you using EG fairing brackets? I ask because the Biketronics and Hawg-wired installation kits are intended for that application.
Carl
Old Jul 10, 2010 | 12:05 PM
Erikh425's Avatar
Erikh425
I just installed a Sony deck with BT kit. It was super easy to install. before I started I got all the tools I thought I was going to need out of my tool box. Turned out it was mostly plug and play except for soldering a few connections and shrink tubing them. Hog tunes looked just as simple, I went with BikeTronics because I could get all of the stuff from Dennis Kirk a little cheaper with free overnight shipping. Either way you go, you will be happy I am sure.
Old Jul 14, 2010 | 07:30 PM
Carisma Audio's Avatar
Carisma Audio
I have used the biketronics kit and have had great success with them, but I also use a arc audio amp and speakers kit to make the speakers perform the way they should perform and sound a lot better than just the chip amp built into the radio
Old Jul 14, 2010 | 07:34 PM
RodeDawg's Avatar
RodeDawg
Biketronics!
Old Jul 15, 2010 | 10:28 AM
meanjean's Avatar
meanjean
Carl
I have the fatory batwing Harley brackets. The fairing I was told is from a Ultra?
