Electronic Aux Switch
Old Jul 11, 2010 | 01:44 PM
OnTheFence's Avatar
OnTheFence
Default Electronic Aux Switch
While preparing to remove my radio to fix my auxillary jack. (Missing right Channel) I noted something interesting. When plugging into the Aux Jack, the radio will automatically switch to Aux and will return to the last position when the plug is removed.
Not sure whether or not the plug is completing the ground circuit or one or both channels, but am thinking a simple electronic switch could essentially do the same.
The goal would be to build a switch that would flip the radio to Aux only when there is voltage on the line. Using my Garmin Zumo, I found that there is a .9vdc on the line when playing music.
Any electronic geniuses out there that can design a circuit to do this?
Old Jul 11, 2010 | 07:31 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
dont know if they can help but ....iron cross audio (in new jersy)has a good rep for doing work on the hk units.think they fix alot of cracked inputs.they will add a pigtail out the back of the unit inside the fairing .
Old Jul 11, 2010 | 08:55 PM
Ultra89Rider's Avatar
Ultra89Rider
If you open the radio up and look at the jack, you would see that there is a contact switch built into the jack. When you plug into the jack, it disconnects and that causes the radio to switch to AUX when there is a plug inserted.
SG-Jay
Audio Systems
Aug 14, 2017 08:20 PM
tinsnips
Jun 6, 2017 09:41 AM
SiggerTX
Audio Systems
May 14, 2015 05:49 AM
msalepeep
Jun 10, 2011 07:00 PM
NitroBerserker
Dec 16, 2006 07:53 PM
