Primary cover bolt stripped - help
Have a 2009 Road King and stripped one of the torx bolts to the primary cover.
1. How can I remove the stripped bolt?
2. Where can I buy hex head or allen bolts? I'm in Germany so need to order via internet.
3. What size are the bolts - are they coarse or fine thread - what #?
thanks for any advice
Derby Cover screws ¼”-20 X 5/8” Allen button head
Use a flat washer too.
Look at post#20 https://www.hdforums.com/forum/touri...-screws-2.html
Pete
Pete
Had the same problem with a timer cover bolt so here is what I ended up doing. Being VERY careful I drilled off just the head of the bolt. Then after removing the other bolts and removing the cover I was able to get the stripped one out with vise grips.
Dolt. After posting I see this was an old reopened thread....
Received 70,862 Likes
09Sharknose
General Topics/Tech Tips
04-18-2012 10:16 PM
