Calling you Hawg-Wired stereo gurus
Old Jul 19, 2010 | 03:24 PM
Jonny Cannon's Avatar
Jonny Cannon
Default Calling you Hawg-Wired stereo gurus
Okay. I haven't received a reply from HW yet, so I thought I'd post my question here.
My bike is a 2007 Ultra with Hogtunes speakers. I also have the fairing lowers speaker kit with the amp, but it only uses the signal from the front speakers. Only the fairing lower speakers are powered by the amp, so it's safe.
I have the T-Bag fairing pouches, which negates the use of the Hogtunes tweeter pod. so, I installed the gauge replacement tweeters from Hawg-Wired. They are awesome - the fit is perfect.
Anyways, it's the same application for all years up to 2010. However, the tweets are 4 ohms. My speakers are 2 ohms. The tweets wire in parallel with the front speakers.
If memory serves me correctly, adding resistance in parallel circuits involves adding the reciprocals. One over the total resistance equals the sum of one over the other resistances. So, a 4 ohm and a 2 ohm speaker adds up to 1 1/3 ohms. Hogtunes uses a 6 ohm speaker for their tweeter pod, which adds to 1 1/2 ohms, when parallelled with a front speaker.
Anyone know if 1 1/3 ohms will cook my Harmon-Kardon (factory HD) deck? I mean, the speakers are listed for my application.
Just looking for some advice.
Cannon
Old Jul 19, 2010 | 03:34 PM
Texas Fat Boy's Avatar
Texas Fat Boy
Sorry, that's over my head. lol
http://www.youtube.com/watch?v=wCy8MpT45gk
Old Jul 19, 2010 | 03:35 PM
PhatTerry's Avatar
PhatTerry
Note 100% sure, but I don't think the same rules apply for tweeters but I could be wrong. I know the Hogtunes Tweeter pod is 6ohms which equals a 1.5ohm load with 2ohm fronts and there are not any problems out there.
Either way you normally won't cook anything without abuse. You'll know if something is out of whack as normally the stereo will cut out fairly quickly from the overheating when played loud. If it doesn't cut out, you should be good.
Old Jul 19, 2010 | 03:54 PM
Jonny Cannon
That's what I figured. Just using one 4 ohm speaker and one two ohm speaker, the difference between Hogtunes pod setup is only 9 amps versus 8 amps.
Cannon
paid4c4
Audio Systems
25
Apr 6, 2018 02:47 PM
danzio
Audio Systems
Dec 9, 2016 12:02 PM
chgofirefighter
Audio Systems
130
May 17, 2016 08:31 AM
kylebru1
Audio Systems
18
May 28, 2015 07:01 PM
cwilks
Aug 13, 2007 10:08 PM
