Anyone experiencing high oil temperatures?
ive got an 2003 road kingand installed a jagg 10 row oil cooler and 2days ago was in NV desert doing 70+mph.... checked oil level often and found it it a high of 229 degrees. while water boils at 212 the 20W50 amsoil i run in my bike does not... nor does it lose its viscosity at 250 degrees and your harley motor is designed to run at 262 degrees and the rear piston doesnt shut down till somewhere around 313 degrees. so long story short is ur bike is running fine but the oil you use expands under heat which explains why you have to much oil so add less at change time and do the same with your chain oil and transmission oil all of which i run the same oil... yes amsoil 20w50.... ride hard
Something else you may try in addition to your already existing oil cooler is this;
http://cgi.ebay.com/ebaymotors/Harle...item4150c73be5
It is a fan unit that will cool your oil when you are stopped in traffic. It is a plug and play unit into your accessory switch. It might help but it is primarily for when you are stuck in traffic.
You didn't say under what conditions your bike was running 250° OT. Was it in heavy traffic or on the road? Were you riding in a tailwind? All these make a big difference in engine temperature. I run about 200-205° while riding 45mph or faster with no tailwind and it will creep up to 210-215° or so in traffic, with an historical peak of 230° that happens only rarely and hasn't occurred yet this summer. If the traffic stops and stays that way for too long it will hit 230° eventually. I ride in S. LA, which is as hot as FL in summer. When I'm in a strong tailwind the OT can run as much as 20° hotter, which makes since because there's less air flowing over the engine to dissipate heat.
I don't think changing oil will make a difference in your OT, and IMO Amsoil is as good or better overall than Syn3, the latter of which frequently gets an unnecessarily bad rap here. It isn't a bad oil, just grossly overpriced. If you're into experimenting try Mobil 1 15w50 or some other synthetic brand next time and see if that makes a difference, although I doubt if it will.
Another long-shot possibility is that your bike is sumping, but unless you've had the cam-chest disassembled since new this isn't likely. Does the bike run well when it is this hot? If performance degrades noticeably after the bike warms up and feels like it's pulling a trailer, this may be the problem. If an o-ring in the cam chest has fallen out or pinched it can cause oil to accumulate in the crankcase, at which time the crank will beat against the oil and cause poor performance and excessive heat. Note that when CHT (not OT) exceeds ~250° on your '07 the ECM will start backing-off on ignition advance, and performance will suffer a bit as a result, but with sumping you will feel a radical difference.
